3D Print and CAD File Repository - 40 Series
If anyone needs 3D printing done for their LandCruiser please feel free to contact me here on mud or via the link listed below! I print mostly in ASA a material that is 10x more UV resistant than ABS, I can print both in SLA or FDM. I can print FDM up to 450x450x440mm :cheers:
Hey chaser, I'd like to make a done light lens for an FJ40. Any chance you could help me? :)
OEM Toyota PTO Winch Gearcase gasket
Let me know if you need a different file type. I have .dxf and .stp uploaded. From what I can tell these gaskets are NLA.
If there is enough interest I would consider doing a limited run of these on my University's laser cutter with rubberized gasket paper and shipping them out for beer money.
I'm also curious how folks feel about the edge width. It's 7mm which is correct by my measurements, but I've seen some examples online of gaskets that peek out from the edge of the gearcase cover, so I would consider bumping it to 8mm and reuploading. Managed to not get a picture of the gasket itself *facepalm* Will take one when I am home
Does anyone happen to have the CAD file for single din Radio? Either the OEM radio with proper mounting, or an actual pocket to replace the radio? Working on a combination of them to 3D print. Thanks in advance.
Toyota used slightly different than a single DIN size - if looking to use the factory dash hole, would need to be sized a bit off from that (vs basing off of industry standard DIN sizing).
