Wanted 3B Input Shaft for H41 /H55f
Pleasant Hill OR.
Looking for a new or good used 3B Input Shaft for an H41 / H55f. I need late type with no taper below the splines. See in the picture. I would be willing to trade for a good used 10 spline F series one.
Thank you
Have you checked with Georg at Valley Hydrids?
So far I've found this.
I know I have the one on this picture somewhere in my pile, just have to find it. But if you can use the one above you can have that.
Let me know.
The one above I believe is for an early style or H engine. I need the one in the picture with no taper in the shaft.
Thank you
I believe what la z posted will work for you. Its definitely 3b and it has an open cage bearing on the input shaft. The late style has a shielded/sealed bearing
The bearing is your best clue regarding fit
@Gearhead I found this one too in my stock too, let me know if your still looking.
