- Joined
- Mar 15, 2014
- Threads
- 1
- Messages
- 10
- Thread starter
- #21
Hey Tom, I'm glad you don't think compression is the problem... those numbers seem acceptable to me, and the engine has lots of power once it's underway. When it's missing, there is a puff of white smoke for every misfire, and lots of white smoke when you rev it up to the point where it misses constantly. As for the EDIC, it stays steady throughout the misfiring, and I have run the engine with the EDIC arm removed with the same result. Also, I've tested the motor with the intake air hose removed from the engine, air unfiltered and direct, so unless there's a blockage inside the intake manifold, below the throttle apparatus, that can't be the problem. On Sunday I played with the timing a little bit {I didn't remove the injector or oil lines from the pump, so I couldn't tilt the pump more than a millimeter in either direction}, and advancing the timing a little from it's current position seemed to make the issue worse. It misfired and ran rough after starting at idle speed unless glow plugged constantly during my 3 min test, and when rev'd up it did the usual shaking with clouds of white smoke. I then retarded the timing a little past it's original position, and it ran great at idle, no need for any glow plug time after starting. It still missed when rev'd up, however. I'll have to try and time the engine properly when I have time, but do you think it's possible that the timing could be to advanced, and that is the cause of the problems? Would that make any sense?
Good news...
