- Joined
- Mar 15, 2014
- Threads
- 1
- Messages
- 10
Hi everybody,
I hope someone can give me some advice on the issues I'm having with my Landcruiser. The vehicle in question is a 1981 24 volt BJ42, with about 310,000 km on it, and a 3B diesel engine {no turbo}. I have searched this forum and the internet in general with no luck.
Here is the problem: The engine starts great {instantly, even now in winter}, and runs good at the lowest idle rpm, after glow plugging it for a minute. However, the engine will misfire {shake, run really rough, white smoke, etc...} after the rpm is raised any amount above low idle. As the engine gets a little warmer, it is able to run at a little higher rpm without missing. At high end operating temps it can be rev'd all the way without missing.
Here is what I have done to try and fix this problem, which has gotten worse over the course of about 2 years: Replaced all 4 injectors with rebuilds, and bled fuel lines {did nothing}, replaced glow plugs several times {nothing}, replaced fuel and air filters, and tested with no air filter {nothing}, drained fuel-water separator {nothing}, added fuel conditioner {nothing}, tried Seafoam engine treatment in the cylinders {nothing}, replaced thermostat {nothing} adjusted valves {nothing}, and replaced injector pump diaphragm. This last "fix" lowered my idle down to where it needed to be, and stopped the misfiring at idle... but only because the rpm is now lower at idle. Rev it up, and it still misfires.
One other weird thing about the misfiring is that it does not seem to be coming from any one cylinder. I have cracked open the nut at each injector to shut off the fuel... when rev'd up in this state, the engine still runs rough with white smoke. I plan on checking the injection timing in the near future, and that is really my only remaining idea, besides checking the compression... although I don't have a gauge. I'm hoping that there is some simple fix that I'm overlooking for this problem, and hopefully you guys have some suggestions. This truck is my daily driver, and works well enough if you let it warm up for 20 min or so, and I'd rather not have to tear the engine apart.
Lastly, on a side note, I also own a BJ60 with 630,000 km and body issues, same engine model as that mentioned above... runs great, and can rev up right off the bat without a miss. In fact, it misses a little at idle when cold, and giving it throttle smooths it out... like you would expect, and the opposite of my troubled BJ42. Thank you in advance for any suggestions you may have on this issue.
