315/75R16 lc series79! please help
Hi there,
i already installed 50mm ARB lift kit and Im looking forward to buy 315/75r16 tires for my 2010 79 series. I dont have any idea about what size (backspace-off set-width) of rims should i have to avoid any issue.
please help
thank you all.. Romin
I know the 18" x 8" steel spare rims seen on many 5 lug 5 x 150 do not fit.
The 16" x 6" stock rim is the best bet unless you can find a 7" rim with minor backspace.
I know the 18" x 8" steel spare rims seen on many 5 lug 5 x 150 do not fit. The 16" x 6" stock rim is the best bet unless you can find a 7" rim with minor backspace.
What Rick said.
100 series 5 lug steelies will be a direct fit. 16x8.
pro-comp wheels had a set 5 lug 150 mm 16 inch .... its had the right back space...
this is in a fzj71 here in venezuela with the pro-comp wheels
These are the toyota 16x8 105 series rims with 315-75 r16
nice truck, do you drive it with stock gearing? if its not, is it oki to drive the car stock with this tire size? thank you
Yes I drove it for a while with stock motor and gears. The std gear ratio in the hzj and fzj 79 4.3 ratio
The v6 has more power than the 1fz it will be fine.
