3 spd or 4 spd
I have my '69 in a thousand pieces, but at least it's all painted and ready to reassemble. I had to buy 3 cruisers to have enough good parts for 1. Now I have a 3 speed and a 4 speed tranny. Which should I install and what are the plusses and minuses w/ each. Engine is original f145 and runs good.
thanks.
If you're a stock nazi put whatever came with it when new.....Otherwise I can't see any decision between the 3 and 4 speed....The 3 speed in mine sounds like its going to blow at speed.....I'm sure its not but that tractor tranny gets loud....I'd love to be able to shift to 4th....
I can't think of any minuses in installing a 4-speed instead of a 3-speed...
Yep, definitely 4 speed if you've got the parts and stock isn't important to you.
Go 4 speed! If you have the adapter for the three speed t-case to work with the 4 speed, you will be even happier. I changed over to the 4 speed and used an adapter gear from Mark' s Offroad to connect the original 3 speed t-case (even kept the vacuum shift). Synchronizers are a beautiful thing :)
Of course drive shaft length will be an issue, as the 4-speed is longer than the 3-speed. There is a good article in the tech section on this conversion. Good luck!
ummm if you aren't sticking to original...why not....5 speed??
Definitely 4 speed. I have the 4 speed with 3 speed transfer case combo and had to have my drive shaft shortened a bit, but it is a great combo.
Another question
Of course, the question now is which transfer case will you use?
If you go 4 spd... wont you miss shifting to reverse thinking your in first
Go 4 sp with the 3sp case but also get a set of 4 sp drive shafts, a new set of drive shaft bolts, and a set of pinion/t-case flanges for the 4 sp drive shaft pattern. That way you get the 4 sp trans w/synch, the larger stronger 4 sp shafts and NO drive line mods. Kurt @ Cruiser Outfitters has the flanges.
My 3 spd works just fine. then again I'm a nazi. As was before stated the final drive for each tranny is the same 1:1 ratio. Therefore highway rpms will be the same. The 4 spd however has a lower first gear and as stated earlier it's synchronized. Two big pluses. 2nd and 3rd on the three speed are synched but that doesn't help at 4 mph when the red light finally turns green.;) Another vote for the 4
I have a 3 in mine , but if the 4 cuts down the tranny noise , I would go with the 4 speed. Remember , The Best Sound ,Is The One You Cant Hear.
