2nd Gen Pickup Body Armor: Front / Rear Bumpers, Rocksliders, Bed Mount Tire Carrier
Snellville, GA
Website
www.youtube.com
Whats up guys!
Here are some pics of the great tube work I got done on the '86. These are all my design and built by the gifted fabricators at Sixditch Enterprises. Let me know what yall think!! :popcorn:
Front Winch Bumper:
-This was designed to be as low-profile as possible, keeping the winch up high and as close to the body as possible for the best approach angle.
-Bumper was built to be super heavy-duty, with 1 3/4" DOM tubing; new plates welded to the front cross member to add mounting points for a total of six 1/2" bolts.
-Down-tubes are kinked to provide for maximum approach angle (underbody was trimmed to allow for this effect).
-Extra support tubes added to stinger for reinforcement.
-Side impact bar stretches the full width of the bumper underneath the grille.
-Dimple-died 1/8" plates add strength and style to the corners of the bumper.
-Tabs allocated for bullet-style fog light turn signals and rock-lights, all mounted conservatively out of harms way
-Removable dimple-died skid plate adds style and protection for radiator / condenser
Rear Rockcrawler Bumper:
-Super low profile, body-hugging design. Also built to be super heavy duty, 1 3/4" DOM tubing; eight 1/2" bolt mount locations (no need to weld the mount rails to the frame like the other guys suggest)
-Mount system includes L-bracket design that wraps the frame rail on the side and bottom (again, no need to weld to the frame)
-Hugs the body with minimum hang-down (bottom tube 1/2" below body, with no gap between body and top of bottom tube; very clean)
-Extra corner impact protection
-Top bars below tailgate add rear impact protection
-Step bar with dimple-died step plate to add strength, impact protection and style, matching front bumper
-two 3/4" D-Ring shackle mounts
-tabs allocated for auxiliary reverse lights and rock lights, all tucked out of the way of impact
Rocksliders:
-Again, built to be super heavy duty, 1 3/4" DOM tubing; 4 legs of attachment
-Hugs the body as close as possible (I elected to trim the pinch seam at the points the legs extend out to the frame; this is obviously up to whoever is mounting them)
-Outer tubes extend 4" out at an upward angle to about 1/2" below an opened door
-These provide an additional upper tube behind each door to protect the cab and bed up to near the bodyline for added protection in tight situations
-Three support legs between inner and outer tubes for superior impact protection
-Rocksliders are removable from welded mount legs via sleeved mounts that are cross-drilled (along with the rockslider legs at the mount points) to be bolted into place once slid onto sleeves (not in pictures yet; coming soon)
Bed-Mount Angled Spare Tire Carrier:
-Heavy duty design, 1 3/4" DOM tubing
-Angled 30 degrees to allow for maximum bed space
-Easily removable and re-installable; Bottom plates are bolted to bottom side of the bed and held into place, with no need to mess with anything on the underside to remove carrier. Simply Impact-out the bolts at each leg and remove; to re-install, start each bolt into the pre-mounted bottom plates, and impact into place.
-Includes lock ring and lock plate for a padlock or other anti-theft device.
-Allocates up to virtually any size tire possible; mine is set up to allocate for up to a 36" tire in its location on the bed (this is the biggest tire I would want).
And just for the heck of it, here's a demo of the rock lights :)
Let me know what yall think of the tube work. Thanks!!:hillbilly:
Nice bumpers, etc. It would've been a little nicer to see you hang around and get to know the forum before joining up with a first post containing a passive advertisement though.
Maybe it's just me though. I like to see people who are a part of us help us and we help them. What's your commission in this?
Nice work man, there's nothing more reassuring than overbuilt parts. Precise and consistent tube work there.
:smokin::beer:
Just looking for opinions on the work, that's all. No need to hate and certainly no commission, just giving credit to my friend's shop that made them. Didn't mean to give the wrong impression here, my intentions are honest. :cheers:
NP. It's obvious you've been on forums enough to know how to clip in img texts..it just seemed odd for a first post IMHO.
:cheers:
How about a build/spec thread for that pickup of yours? Simple store bought rock-lights or something home made?
:cheers:
relax a little, the guy is simply proud of rig and the work he's done on it. He's obviously new to mud, so what. If his ideas give others inspiration then more power to him. I've seen this rig first hand and it's very clean and well thought out, hell, I wish mine still looked as clean. Not to mention, not everyone has access to the tools needed to home brew parts so just let it go. Now please, go about your business Matt
relax a little, the guy is simply proud of rig and the work he's done on it. He's obviously new to mud, so what. Matt
Thanks tkinze, I'm pretty sure we already sorted that part out amongst the two of us. Carry on..
*Small Suggestion: Factory Tech Trick
Flip the lower nuts/bolt/washer assembly around so they face into the frame instead, it'll appear cleaner and more factory. Also inherently it'll protect the threads better from road debris in case you need to ever undo them..same way Toyota does them at the factory. :D
:smokin::beer:
I LOVE things overdone...as long as they are practical and look good. For example, I may be stepping on toes here (sorry to those that I am), but I'm not a big fan of exocages...in my opinion, if you're that worried about your precious body panels, don't crawl the darn thing (I don't with mine); stick to challenging trails and buy a beater to bash or build a tube buggy; probably wouldn't use much more tube anyways lol. Preciate the compliment!! :cool:
relax a little, the guy is simply proud of rig and the work he's done on it. He's obviously new to mud, so what. If his ideas give others inspiration then more power to him. I've seen this rig first hand and it's very clean and well thought out, ****, I wish mine still looked as clean. Not to mention, not everyone has access to the tools needed to home brew parts so just let it go. Now please, go about your business Matt
Preciate the support tkinze, no harm no foul. I must say I am pretty proud of it though :grinpimp: haha...looking forward to the Christmas party!!
I really wanted to, but didnt for a few reasons; 1. If you reverse those bolts, they would come very close to contact with the side support bolts, and would make installation and removal a royal pain in the arse...2. The bar you see in the picture (between the two bolts, reinforcement for the receiver tube) sticks almost 2" past the bolts, so it would be pretty difficult to even scrape them...3. They are only seen when you look up under the truck, so ease of installation / removal took priority over looks; the bumper weighs almost 100 lbs and takes 3 people to safely install it, so the quicker the better:D
OH, and a build thread will be up next. Going to take a minute for that one...got to snap some more photos. :whoops:
That's a clean rig! Protection is the right thing to do on a truck that nice.
I'm diggin' the front bumper too. I'd have to go with a little different hoop style, maybe shorter or something...
Hey! Let's wheeeeeeeeeeeeelllllllllll!!!!!!!!!
Yeah, if I were to change anything, that would be it. The hoop / stinger is a little overkill, but it's grown on me.
and I'm down for wheeling man!! However it desperately needs a locker. Know any good deals on a Detroit? PM me if ya want to hit up some trails!!
Dunno of any "deals"... I'm sure they are out there.
Lockers sure are nice. I've wheeled both ways.
If you can afford it, get a selectable Toy E-Locker or ARB. My Lock-Rite works great but it doesn't like the pavement sometimes. Ok, the driver doesn't like it on the pavement sometimes :crybaby:
Gotta couple wheelin' trips scheduled.
Sending PM
Sending PM
Sweet, got the message. Beasley sounds like a good time. I am actually looking into getting a TRD E Locker as well...just gotta find one for a decent price.
Nice looking rig. I love the front and rear bumpbers. I would like to fab something similar for my 89 4runner.
Any of you guys know where I can purchase this kind of bumpers I have a 1994 Toyota truck extended cab and I’m looking for something just like this. Really loving this set up.
Check out Addicted off road. Their bumpers look a bit similar to me.
