So the only way to do it would be to upgrade the ECU if that is possible
That sucks
That sucks
You still don't get it...pushing the button starts you off in 2nd. We still get third and overdrive while that button is pushed. When your ride is in 2nd, that's the only gear you've got. Do you understand now?![]()
not all 80 's have 2nd gear start my 94 will start in first then to second when the shifter is in 2nd gear
Can the button be added to my 94 is the question?
There was one thread I found about it and the same question never got answered.
The 2nd gear start button showed up in 1995 when 80's got the A343F transmission.![]()
I found a use for it the other day while crawling in traffic. I pushed the second start button and shifted into 2nd--then the transmission didn't have to keep shifting up and down with the starts and stops on the freeway. I'm not sure it was that beneficial for the transmission, it but it made me think so. I also felt half an IQ point smarter.![]()
My JDM built in 11/96 comes with A442F ECT and 2nd start.
Most of my driving is in the city so I've been using the 2nd start as a fuel saving measure. Anybody see any negatives to using it more often than not?
so if you don't push the button and manually shift to second it starts in first right?
(still getting my head around it...)
a
I wouldn't recommend it for high range starts. Unnecessary wear on the transmission. This would generate too much slip. I don't think there would be any mileage advantage to not using first gear. You're going to use more load on the engine (vacuum) to accelerate, which would negate any gearing improvement.
