The Coolant Hoses in question finally arrived. The (2) hockey stick shaped hoses above the Crank Pulley fit exactly from the 3L.
#87245-89281 - Upper Water Hose (shorter)
#27245-89282 - Lower Water Hose (longer)
Above the (2) Hockey Stick Hoses, is Turbo Water Hose #1 - #16284-54020
The manifold above the crank pulley that connects all the little together is "Water Pipe Sub-Assy" # 87208-89144
Water Pipe Sub Assembly "A" - are the longer water pipes above the Exhaust Manifold # 87208-89143
However, the rest of the hoses are a NO GO.
I just did a work around... we shall see how long it lasts, but the smaller (4) smaller hoses on the thermostat side of the engine cannot be adapted from the 3L. #87245-89279 & #87245-89280
I thought it would be a matter of just cutting them to size/length, but it didn't work out. There would have been some "kinks" in this solution / or too short. Best solution, just get some 5/8" Heater Hose from the local parts store. I was trying to stay Toyota with this, but it just didn't work out this time.
The Heater side/ Turbo side of this water manifold is 17mm and the Thermostat side / Intake side is 19mm, if that makes any sense.
