2h conversion
Goldcoast
Hi recently ripped the 3f out of my fj73 and picked up a 2h to swap in.
Just wondering on things i should know
I know wiring bellhousing, radiator fuel lines engine mounts have to be changed and thing else i should know?
The other question is to do with the 2 vac line routing, i know they run off the alternator but where from there brake booster? Not sure
cheers
Vaccuum needs to go to brake booster, transfer case VSV if you have a vacuum shift transfer, shut-off VSV if the 2H came with an auto transmission, and clutch booster if you have this.
Factory setup alternator vacuum pump goes to a reservoir under the driver's seat area on the chassis rail.
