2FE rating vs 3FE
cruiserinsanity
Alabama
The 3FE is factory rated at 155 horsepower and 220 ft lbs of torque, the 2F is rated at 135 horsepower and 200 ft lbs of torque. I understand that the 2FE bumps compression, but how much more power/ torque would it make over a 3FE?
Not enough to make much difference in a fj60. The fj60 needs a bigger engine. A 2fe is a 2f with higher compression and efi. That's all it is. You can get the same thing by shaving the head on a 2f and adding a sniper kit. Drop in a LS motor instead or a diesel. That's what my research has concluded anyhow. Some claim to be able to get 200hp out of a wound up 2f conglomerate. That might be ok in a fj40 I guess but not a fj60.
I’d be curious to know too. I’d hope it would be the same if not more than the 3FE but I’m probably dreaming.
