Pull the distributor and use a drill with a old screwdriver shaft - turn the oil pump clockwise= pressure to the galley and look for leaks
Jim please ship a few plugs. I could use them for sure. Thanks again.Yep, Welch plug and cup plug are two different things. Welch plug is used to close the oil gallery that goes all the way through the block. It can be threaded to 1/2NPT, but I don't bother anymore. The block is HARD, and cutting a good, deep pipe thread is not easy.
I can USPS Priority Mail a couple of the welch plugs to you for $10, if that would help.
Where did you buy your plugs?This is part of the oil circuit.
Yes that's what I am referring to. See the third photo in this post.
The welch plug is meant to expand in the hole. If it is hammered past flat its diameter is smaller than if the disk was flat. So You want this to expand as much as possible. I just don't know if mine is tight enough. And then it needs some sort of sealing border.
Here are some photos of the plug un-installed:
Where it is on the back of the motor. Notice all the oil:
Mine was leaking and leaking a lot. I thought about installing a new plug but did not think I could do a good installation while lying under the Cruiser. I cleaned it well and packed the cavity with the ubiquitous blue Peramtex goo, overfilled actually, and slapped the bellhousing back on. I may have added a layer of duct tape but don't remember for sure. That was about 2 years ago and a ton of miles, still leak free.
I remember having to do this about 7 years ago. AFAIK the engine had never been out before, but mine was definitely threaded - no idea if that was a later-year "fix", or a previous owner finally had enough... May be worth looking into as a potential fix?This fix lasted about 6 1/2 years and now the leak is back.
View attachment 3021174View attachment 3021175
