Agree with all Toyota gaskets and similar parts. When I did my rebuild (did it myself except for block and crank machining) took me about 4 weeks rushing to make GSMTR (blew it 6 weeks prior). My costs - about 8 years ago was $1,300 in parts/machine shop, with fact I used aftermarket .020 pistons. Everything else was Toyota. My cam and lifters were good. Only thing I'd have done different was consider an aftermarket cam - maybe pony up for brand new lifters, and shave the head a tad. Since adding FI and EI - it runs plenty strong enough - least past the point of sanity of running 80 mph on the I-State.
For as far along as you are - if you have the funds, I'd rebuild - the hardest part is getting the stupid timing cover backing plate gasket to seal properly (e.g. inch/lb torque settings done ever so gentely). The rest is easy - right Marshall
At 104,000 it really is just broke in - and might not need a rebuild BUT If you've got the side cover off - pull the valve cover and lifter assembly so as to get the lifters out and inspect - if clean, keep em (I have a thing for putting each item back where it came from - so much so that I stamp my connecting rods for rebuilds, etc.). Check bearings as Marshall suggested. Pull head and replace gasket so as to give you a chance to inspect cylinder wear and pistons. If the vehicle ever had a vacuum leak at the booster - you might find damage on the #4 piston top. Oil pumps are pretty reliable with that mileage. Water pump replacement - just do it. While inspecting the thermostat housing double check that there's not excessive corrosion inside - sometimes this happens and you have a very weak or future leak prone housing.
Definitely go HEI while in there!
Best of luck. Bill.
Best of luck. Bill.
