- Thread starter
- #61
So it’s basically extend 5/16 hard line. Or remove the original 5/16 hardline completely and run 3/8 hose from the efi to the tank?In regard to your plumbing pics.
I got the base unit and not the kit but looking at the kit, it comes with 3/8 ID hose and I am sure the fittings on the pump and filters are also 3/8. Where you clamp the hose onto the existing hard lines is of concern. The stock hard fuel lines are 8mm which is almost exactly 5/16. Clamping a 3/8 ID hose onto a 5/16 tube is risky for sure. Also, you should not put a hose onto hard tube unless it is beaded. If you’re going to use hard line it should be 3/8 OD which also matches up with -6AN fittings.
