Well I drove the 60 to work this morning ~17 miles. It ran like a champ. After 10 miles or so down the intersate ~60 mph, it looked like the needle was a little bit above half way. When I exited the interstate the needle rose to a little bit more than 3/4. Not in the red but more than normal. After I got moving again from the stop light it barely came down, so I turned the heat on, and kept on driving at ~45 mph. I don't know of it was turning on the heat or driving at a slower speed but the temp went right down to normal. After that all was fine. I drove another ~5 miles @ ~50-55 mph to work. When I got to work I let it idle for a minute or so and it didn't heat up at all. I checked the coolant overflow tank and it was a bit below the low level. So I filled topped the overflow tank with water.
I had planned on flushing the system anyways. I just don't know if I need to change the thermostat and/or the water pump while I'm at it. No leaks anywhere and nothing no coolant in the oil.
What do you guys think?
Thanks,
Chris
Thanks,
Chris
