2F-E in Africa - Aftermarket ECU
The 3F-E was never released in Africa ( intially the 1FZ was also here in carb version ) .
So following my 2F rebuild ( https://forum.ih8mud.com/60-series-wagons/399712-another-2f-rebuild.html ) I decided to convert to Efi.
Most of the part got imported but due to the difficulty in obtaining parts the decision was made to go with aftermarket ECU .
Here is the intake manifold and a local header system : ( I had to make sure it would fit as it was designed
for 3F carbed engine )
Now I need to rid the manifold of all the unnecessary vacuum pipes .
With the aftermarket ecu we only need :
Lambda sensor , MAP sensor , TPS , ICV , water temp sensor , air temp sensor .
EGR is already removed and we do not need the cold start injector ( the aftermarket ecu takes care of that )
I studied the threads and service manual but still unsure of a few things :
First question :
in the following picture ( taken from Pappy's rebuild report ) where does the pipe go that exits where the arrow points ?
MORE QUESTIONS TO FOLLOW
First question :
