250k rear wheel bearings? Really? (1 Viewer)
FOG TOWN->SF<-
Okay. It all starts with installing a rear spartan, then heck, axles are out and let me see how the bearing are.
So I take out the nut and this is what I see. Really? 250k and I don’t really see why I should replace the bearing. I’m thinking new seals and just repack the old bearing and call it good. I have another set, came with the kit I bought from Australia on eBay. Rears are the same as the front and see more damage from fronts. Okay would you or not? And why?
Bambusiero
Chandler, AZ
Inspect & re-use if looks OK, replace only if clearly needed - OR of you just feel better with a "good for the duration" preventative replacement.
Nframe
Wisconsin
You'd be fine just repacking and reusing.
Mine were the same, and I replaced with a new set, and kept the old bearings/ races for backups.
I had it all apart, and figured just put the new ones in so I knew the life of them. Not a hard job to drive the old races out and replace.
cvenom96
Frederick, MD
Same.
flat earth Midwest
If I had things all apart, I'd probably go ahead and R&R the bearings. . Yes, the old are still good, but putting new in will take the truck far past when I'll even care. I'm not getting any more limber with age
SNLC
OCD
Supporting Vendor
Boise - Idaho
Why are some people trying to make this all about race?
I learned many things from a guy who worked in a diff shop for years and has rebuilt thousands of diffs. He taught me to look at the race first, the actual bearing it will be obvious if it has damage, the race is where you see the wear.
Cheers
SNLC
OCD
Supporting Vendor
Boise - Idaho
Oh and a lot of people on the forum learning to turn a wrench or trouble shoot their Cruiser. So being plain and simple often helps them. 😉
Cheers
