If your engine has the same emissions equipment mine has, then your problem is 1,000 percent normal. That high idle burns-off the excess air/fuel mixture in the intake when/after you decelerate. If that did not happen, then your engine would be too loaded-up as you approach/sit at a red light, the engine could flood, then die. Additionally, your engine would not give that excess air/fuel a full burn, and it would be thrown out the tail pipe as emissions. This is also one of the problems guys have when they believe they do not need a VSS with thier fuel injection conversion. The VSS and Ignition Module control these idle functions.
If your problem is far in excess of this normal situation, then have a mechanic check into your idle functioning????
