- Joined
- Apr 29, 2013
- Threads
- 52
- Messages
- 547
If Toyota is releasing the GX with the TTV6 and holding off on the Hybrid version to obviously supply the new LC....when could it be possible for the GX to have the Hybrid?
All Land Cruisers are equipped with a full-time four-wheel drive system with a center locking differential and an electronically controlled two-speed transfer case with high/low range. The system also features vehicle stability control (VSC) and an automatic limited-slip differential (Auto LSD). An electronic locking rear differential is standard on all Land Cruisers and can help split power 50/50 to the rear wheels for improved traction control on rough terrain.
I’ve noticed no discernible difference with/without KDSS. Perhaps if I were able to drive one with and one without back to back but in the South/southeastern part of the states all 4Runners (excluding Limited trims) come without KDSS. I did feel like the GX460 and 200 Series have a more comfy ride but I’d say that’s due to the sum of their parts, not just some sway bars.What happened to your kdss? Ive seen maybe 5 kdss leaks in 10 years on the 4runner forum. I wouldn't own a 5th gen without kdss.
I'd pass on xreas though. It's trash. Notorious for leaking.
Did anyone else read more about the "vehicle stability control" (VSC), I've googled it and no reviews discuss it.
Has Toyota or Lexus used this on any other models under different names, akin to "Rollover Control" or something?
Once you can decompress (and hopefully NDAs expire) I would be very interested in hearing your detailed thoughts on the platform and the chassis and of course your thoughts between not only the 200 and new 250, but also how the GX plays into the roll.I'm excited to finally be able to talk about this neat platform. It’s been an extremely busy few days with this LC project and before that with the GX550. I need to drive my FJ40 around for a few minutes and reset my brain so I can put words together.
Short answer, I give it two thumbs up.
this guy loves the 250, he has a lot of time behind the wheel of the 120 and 150, and he says this is the best looking one. Also noted that he loves the interior. He usually isn't popular with the OEMs as far as his opinion goes.
It's even on my LS430. Great technology.Did anyone else read more about the "vehicle stability control" (VSC), I've googled it and no reviews discuss it.
It’s early and these are preproduction vehicles. We are still months away from release. We will get more details closer to release.Anyone else feel they would have liked seeing more engineering videos and stuff?
What about the usual videos showing the new features and stuff
You know the one Toyota makes using weird graphics those ones.
Where are they?
Sometimes I feel this reveal was rushed honestly.
I'm not sure how. Ekdss just means it's electric shutter valves instead of the floating ball valves used in the lc200. It's still a hydraulic system. And the 4runner version has had electric valves since 2010 in the central control box. They've never been an issue.I'm assuming the E part of E-KDSS solves the potential leak issue.
Honest question...Add Ford’s “full time” 4wd option which is not the same as legit full time 4WD the LC has. Add their tow package which is 1,500 lb less plus you are getting less interior storage/payload. Throw in a hard top and automatic to get it closer to the LC base spec and you’re right there at $53k and could easily get to $55k or more with a few more options.
So yes, you could spend less but you also get less.
3 months from actual production isn't that long.It’s early and these are preproduction vehicles. We are still months away from release. We will get more details closer to release.
Every vehicle has vehicle stability control. It uses an accelerometer plus steering wheel position sensor plus the ABS system plus the electronic throttle to reduce the chance of a spin. If the truck starts to oversteer, it cuts the throttle and uses differential braking to bring the back end inline. My 2003 4Runner had it.Did anyone else read more about the "vehicle stability control" (VSC), I've googled it and no reviews discuss it.
Are you sure you've driven one with kdss? It's a huge change in vehicle dynamics. It's like comparing driving f250 vs f150.I’ve noticed no discernible difference with/without KDSS. Perhaps if I were able to drive one with and one without back to back but in the South/southeastern part of the states all 4Runners (excluding Limited trims) come without KDSS. I did feel like the GX460 and 200 Series have a more comfy ride but I’d say that’s due to the sum of their parts, not just some sway bars.
Toyota uses a Torsen center diff which is bulletproof. Ford uses a computer controlled clutch pack which can overheat, and when it does overheat, it opens up so you are in 2WD.Honest question...
What's the difference between Fords full time and Toyotas Full time 4WD systems?
I guess I’m lucky. I got 130k miles out of the XREAS system on my ‘03 4Runner and I’ve got 95k miles on my 200 with KDSS. I like KDSS as I get decent articulation off-road and on-road the sway bars keep the 200 from rolling like a pig in turns.I'm assuming the E part of E-KDSS solves the potential leak issue.
I agree with everything you said 100%They are basically hand built so limited production. The people who need them — mining companies in Australia and folks who spend a lot of time in the Outback — really want them.
But for the average folks here on Ih8mud who claim to want one, I think they would change their mind if they actually drive one. The NVH on the 70 series is horrid. The interior is cramped. It has all the disadvantages of a solid front axle during daily driving. The front track width is wider than the rear, resulting in squirrelly handling in snow and sand. The solutions to that range from janky (different offset rear wheels) to good but outrageously expensive (aftermarket rear axle).
If you spend a ton of time off-road, then yes, you might like a 70 series. But most of us spend 95% of our time on pavement and the 70 series is far worse on pavement than a 200 or the new 250 or a 4Runner, etc.
So I stand by my statement — US enthusiasts who long for the 70 series simply want it because it is forbidden fruit. If they actually drove it, most of them would hate it.
The 70 Series has the romantic appeal of overlanding in the Outback or Africa. But most of us spend our days commuting to work in stop and go traffic, dropping the kids off at school, or going to the grocery store. For all of those everyday activities, any modern Toyota truck is a better choice than a 70 series.
I’m not certain but this is what I pulled straight from Ford. I had this feature on my last F-150. There is a setting called 4A that you can switch to which does the below:Honest question...
Yeah I don't understand the logic of this reveal... Supposed to be a world wide vehicle but this reveal was in the end very US centric.Anyone else feel they would have liked seeing more engineering videos and stuff?
Where are they?
It is my understanding that Toyota is at capacity for the 70 series, which is why there are long waiting lists for them.I agree with everything you said 100%
But just an FYI to everyone here
Yes aspects of thr LC70 production may be considered hand built I guess maybe like some of the welding maybe? But it is far from limited production.
They make alot of them.
Probably more than the Lexus GX per year easily.
So it's definitely far from being limited production.
You should see how much they export to the Middle East alone.
