2024 Available Tow Hitch Options Roundup (4 Viewers)
Santa Monica, CA
I want to get a hitch bike rack, which means I need to install a tow hitch. There are a number of threads about this over the years but I figured it might be useful to try round up what's available as of 2024.
My parameters:
* I don't see myself actually trying to tow anything with my 3F-E and A440F given that my home base is penned in by mountains.
* I do care about being able to work with a rack designed for a 2" receiver
* I would prefer not to drill holes through the frame
Reese 44668. Mud post: "We had to drill holes in the receiver brackets to clear the rivet heads. only one bolt per side on the frame matched, we drilled out the frame for the second mounting point at the front of the receiver bracket. Also had to enlarge the holes at the rear just over the 2" receiver tube to allow the screws that go into the bottom of the bumper + frame. Still need to get some 0.5" spacers for that part."
CURT 13402 Class 3 Trailer Hitch, Mud post: "The fit was not perfect. I had to do some grinding on the hitch to get the holes to line up with the front factory holes in the frame. I also had to drill holes in the rear of the frame to accommodate the hitch. Had to use spacers to rear the rear frame rivets like most do as well as a spacer where the hitch attaches to the bumper. It was more work than needed and I wouldn't underestimate the effort it takes to cut holes in that Japanese steel. It sucks."
Draw-Tite 75725, Mud post: #post-12691383 "Its not listed as a direct fit to a 60 but it lines up very well with the frame rails and the two bolts that mount mid bumper line up perfectly with the existing toyota bolts... To mount this we pulled the tow hook off the passenger side frame rail and reused those two bolts on the mid bumper mount on the hitch. The hitch comes with two carriage bolts, matching nuts, and retainer plates. We used these two carrage bolts on the rearward most frame rail mount holes....these line up with both the holes in the hitch and the frame. We then center punched the frame for the remaining 4 holes (2 per rail) and drilled them out to 1/2" diameter. We used new 1/2" hardware to bolt the hitch to the frame. Note that we also used (2) 1/2" fender washers stacked on each of the forward most and rearward most bolts. The bolts in the middle dont get washers because thats where the rivets are in the way. These washers give you the clearance needed for the factory rivets in the frame.
Lastly once the hitch is bolted to the rails there will be a gap between the hitch and the bottom of the stock bumper. We happened to have a bar stock of auminum that was the proper width to be a spacer. Milled a couple holes through the spacer and bolted it up. "
BTB 2″ Receiver Hitch for 1980-1990 6x-Series Toyota Land Cruisers: "This is a bolt on receiver hitch for a 6x-Series Toyota Land Cruiser. This receiver hitch uses a 2″ Tongue (Not Included). Drilling is required for installation. We recommend using Grade 8 hardware for installation. This kit does not include hardware."
Curt 11812, Mud post: "This is a proper fit hitch specifically made for FJ60/62 trucks and fits directly without any sort of modification to the vehicle or hitch. No holes to drill. Just bolt it up. Again this thing is pretty much brand new and hardly used." Downside, it's a Class I. Dealbreaker for my purposes.
CruiserParts 1981-1990 FJ60 FJ62 2" Receiver Tow Hitch - looks like a Curt, can't read the number, possibly Curt 13402 "This direct bolt on trailer hitch is for the 1981-1990 Toyota Land Cruiser FJ60, FJ62, HJ60, etc.This mounts utilizing the factory tow hook bolt locations and you can either drill out and use the 3rd mounting hole for heavy towing or leave no 3rd bolt in it for lighter towing." I have two big questions about this: If it *is* the Curt 13402, @Gretsch's post above makes it sound a lot less straightforward to install. Second, I'm not sure what to make of "just leave out two of the bolts".
nothing at cruisersolutions, classiccruisers, or cruiseryard, ccot, cruisercrap. None of the curtis/draw-tite/etrailer type sites list anything.
Am I missing anything? Basically, it sounds like there's no currently-available option where you don't have to drill holes in the frame rail, unless you'll settle for a Class I hitch or trust the CruiserParts assertion that you can just run with four out of six bolts installed.
This adds nothing of value to this really detailed and well thought out post, but my favorite hitch option is a dual swing out bumper like 4x4 labs or trail tailor or dissent offroad. a man can dream.
are oem hitches (aka far rear skid plate) that hard to come by? Mine is still on my truck, i figured they all had them
Ha, of course it does...where would be without dreams...
I've found old posts with links to what look like at least dealer-installed hitches, but they're all NLA at this point. Probably something you could snag at a junkyard?
The cruiserparts people responded to my question about whether their hitch is a Curt 13402: "These are bolt on. You do not need to drill holes in the frame. They have plates that sit in the frame rail and the bolts will thread into those."
Another followup from the service desk at cruiserparts:
"So on the 60-62 the back two bolt holes go straight into the tow hook holes on each side. The 3rd hole closer to the rear axle would need to get drilled out and a nut in the frame. Most people don't hook that one up. If all you are doing is using it for a bike rack just use the back 4 bolt holes(2 on each side). If you are towing alot with it then you would need the other one drilled out and bolted. These do have spacers that sit between the frame and the tow hitch. Its a flat piece of steel with a hole in it. Sorry for the confusion. I had to go look at one ha."
I'm kinda convincing myself that the two bolts option is ok, since the Class 1 hitch only has one bolt and bike racks for a 1.25" receiver are rated up to 150 lbs.
I was needing a tow hitch too so installed a 4plus rear bumper tire carrier. Also installed trailer wiring from a vendor on this board. Works great. I tow a small trailer and motorcycle. Also I have the hitch extension in for my mtn bike carrier to clear the tire and basket. It is solid!!
Just FYI, my experience with this hitch was that once loaded with bikes it becomes fairly springy and flops round a lot while driving loaded. One bike is prolly fine but if you carry multiple you may risk having them touch the ground going over bumps. I found the class one to fit fine but it's just not sturdy enough to do anything with any weight. I dumped it because of this and sold mine here on mud.
In my Curt 13402 install thread, I made it sound like more of a chore than it was. It does not fit up exactly and you have to do some modifications but with the right tools you can make short work of it. There are just likely better fitting hitches available. I just didn't want to go through the gamut of options finding the perfect fitting one. I see these trucks with old hitches on them that seem to bolt up perfectly but found it frustrating I just never could get part numbers for them. So, I just rolled with this one. If doing this again I would roll with the BTB hitch to avoid the hassles. You'll be happier with the BTB hitch, I think. With any of them I'm not sure you can avoid drilling into the truck. Just have some really good drill bits available with plenty of lubricant. HTH.
Yeah the class I definitely won't work for me, I want to be able to carry ebikes. I'm just comparing it to the cruiserparts option with 4/6 bolts installed. (I'm leaning towards a 1up rack that requires 2" receiver).
Yeah sorry here. I re-read your post. I thought you were talking about the curt class I. I'm with you now.
I still dream of a 4x4Labs or Dissent rear bumper (only took Trail Tailor off the table because Jason's scaling back production; which come to think of it I don't think he's even taking new orders for bumpers at this point).
For me i just want something that will protect the rear quarter panel. Id take a smittybuilt at this point if it protectected the quarters haha
@Gretsch just out of curiosity why the BTB over say the cruiserparts or the curt? I feel like everything else the same, drilling two more holes for the cruiserparts is better than drilling all six holes for the BTB. Maybe the BTB matches a couple of the existing holes and I'm just not getting that.
I'm so annoyed the bolt up ones are so hard to find. I've already got three perfectly good bolt holes in each rail, two for the recovery hook position in each side, and another one a bit aft of those.
Does make me wonder if it would be more straightforward to drill another couple holes in _the hitch_ that fit four out of six and use the other two holes I have vs turning my frame rails into drillium.
At the time I looked at this (its been years now), the BTB products was the only game in town for fit-up on one of these, at least for a new hitch. My understanding then was that it was set up to be truly bolt on and line up with existing holes. My only issue with it was that they are so proud of it and I could get the curt much cheaper. Looking at the BTB photos, it looks to have 4 holes for the frame rail mounting, and two for the bolts in the bumper. On my cruiser, it already had 4 holes in the frame and two in the bumper. The two holes in my frame were more towards the rear of the cruiser, and the holes I had to drill were more towards the front of the cruiser to use the curt. My assumption was that the BTB was specifically designed for our cruisers to line up with the already existing bolt holes such that you wouldn't have to drill any additional holes in the frame, which I liked. I'm not sure what the drilling is they are talking about in their description. I don't recall that requirement when I looked at this years ago. Maybe it was and I just missed it at the time. If you still have to drill a hole in the frame to use the BTB, then maybe there is not that much of an advantage to using it.
As mentioned, the Curt 13402 kind of lines up, but I had to make modifications in both the cruiser frame and the hitch itself to get it to mount with every available hole. So, seems that even if you had to drill and additional hole in the frame, using the BTB would still be less work than the Curt option I used. With the Curt, to use all three hitch mounting holes on each side of the frame, there is a factory rivet which forces you to stand off the hitch at four locations if doing that by using a spacer of some sort to get the hitch to clear the rivet head, which just complicates the install even more. It's all pretty mindless stuff, but still it seems the BTB would be easier. One thing on the Curt to keep in mind, is that it does not sit flush against the bottom of the bumper. There is a gap between the bottom of the bumper, and the ears where you put the bolts into the threaded factory holes into the bumper. I had to add a spacer there to stabilize the hitch. See here:
I believe the BTB hitch is designed to sit flush up against the bumper eliminating this gap. It annoyed me a bit to have that gap and would have preferred to have it more flush against the underside of the bumper. If you wheel your truck, having this lower could get you hung up on rocks. Not a huge deal but something to be mindful of.
I don't know what the deal is on the CruiserParts hitch is. I don't recall that being an option when I looked into this years ago. If it's just the Curt 13402 hitch I used, well then it requires all the work listed above to install.
On a side note, it doesn't sound like you are towing stuff, but if you want a really nice plug and play trailer harness for your 60 series, my friend's business makes a really nice one found here:
He is a one man show but he's good people, so support him if you are so inclined. HTH.
Got this in email from BTB:
"Hey,
This should bolt to the existing holes on the frame.
Thanks!"
This was always my understanding of the BTB option at the time I looked at it and the reason I considered still going with it despite its high cost. Wouldn't make sense to create a custom hitch design for a specific vehicle and then force customers to drill new holes in said vehicles frame in order to use it when there are already existing holes available. As long as you are designing something like this from scratch, might as well make it easy for customers to use it. The premium cost of this option lies in its custom design and ease of use. Value of this bit drops out quick if you then have to do a bunch of your own custom work to mount it up. For me if doing this again, I would roll with the easy button on this and go with the BTB. You'll run into plenty of other challenges on your Cruiser that won't have such an easy solution available if keeping it for any length of time. The Curt option I used was admittedly a hack. I got it to work but you could make any myriad of available hitches work with enough grinding and drilling. Looking at photos of the BTB, I think it's set up to also clear any rivet heads you would encounter while mounting this up. They seem to have thought of everything. Use their knowledge OP. This is the route I would go if doing this again on mine. GL and HTH.
I second the 4Plus bumper. There is no lose to departure angle since the receiver is in the bumper.
I have installed the backup lights since the picture was taken.
That will actually improve rear departure angle since there's no hitch bolted below the frame rails.
