Parting Out 2011 HZJ LHD chassis and parts PA/MD
York, PA
HZJ76 and 79 series parts/chassis
<100 miles, everything like new
Frame
Suspension
Axles with 4.30s, rear limited slip FF, new 5lug pattern
matching set of 5 rims and tires
Steering box, tie rod(has the old school greaseable and adjustable TRE) and drag link
Radiator with fan shroud
A/C condenser
Brake booster, master and pedal assembly, chassis brake lines
Clutch master and pedal assembly
Fuel tank
Exhaust
No title, for parts only.
Located in Waynesboro PA right on the Maryland line.
$3500 for everything
Spare Tire
Front Tire
The wheelbase is 106"-107". The chassis is from a 76 series. There is also a 1/4" hole drilled in top of the fuel tank. This was used for a webasto fuel pickup.
My buddy sean is dying for those tires.
I already sent you the PM for some stuff a few days ago.
remember, not all that hard to switch the rear end to 6 lug pattern and your market would include 40, 55, and 70 series owners.
Front end would be a donor for 80 series crowd but needs the 6 lug conversion (80 series arms, springs, and width are all the same)
I have the same frame here in tucson for a different project.
to be clear, this is a 76 frame (4 door 70 series) and not the 79 chassis, correct?
What size are the ring and opinions? I am very interested.
Thanks.
Dan
Was this from the blue truck that had the top smashed in? IIRC, that truck had the roof chopped and then became a yard truck for a bit before going on ebay.
Oil....that rig was still pretty sweet - as a convertible :)
Too bad they don't bring 'em here and give 'em the good 'ol "Overpass Treatment" more often :)
