I have replaced my 2009 LC headlights with 2013 LC headlights and purchased the wiring adapter harness that was mentioned in one of the posts about this upgrade.
I am having these issues.
When I start the vehicle with the lights off, the high beams come on and the passenger one is very dim, while the drivers' side is bright. I checked the voltage on the passenger high beam and it shows negative (-) 12.9 volts.
If I use the turn signal, both high beams flash at the same time, instead of the correct turn signal. This happens at all switch locations, unless I turn the lights to on.
When I turn the lights on, (the one below "auto"), everything works properly.
I have attached the wiring diagrams for 09 and 13 and it appears there is some differeces. I am trying to figure out how to make this all work without having to rewire/splice everything.
