Please let me know if anyone can physically find this:
<snip>
I would love help locating: FE4, E60 junct, FE5
@TXSunDevil suggested that Fg1 might exist as an unused plug in the Nav models, but after taking apart the entire center of dash, I can confirm it does not. Sadly, there are no unused plugs in the 200. Therefore I tried to locate FE5, which the diagram shows as being on the right side of the cd module. I was not able to locate it. I did find:
<snip>
If I can't find FE5, then I need to locate the Main Body ECU E2 (behind far left side of dash). I see the location in the diagram, but the complexity of the wrapped wiring behind the dash is proving to be the biggest obstacle. Any help given is appreciated!
Let me know if it'd be of any benefit for me to get back into the dash.
I have the full FSM... PM me if you need copies of any wiring diagramsBy the way, $20 for 2 days access to TIS isn't bad at all. I had to pay three euros for 1 hour access to Toyota EU TIS
Here are the clock, AC and stereo diagrams for the European spec 2008-2012 200 series, it might be of help
I have disassembled one a while back. Is there an electronics supply store in your area who could show you and maybe have a special tool?
It looks like every year is a bit different creating problems for a plug and play solutionIt sounds like the climate unit wiring is loose at the harness. It could be the ground or any wire really.
If you get this working I hope you'll do a full write-up with wiring diagrams.
The ultimate solution would be if one could buy the Toyota wiring connectors separately and create plug-and-play harnesses, but that's probably a pipe dream since half the connectors are part of the head unit.
There is on another thread how to spoof the air bag with a resistor...
