2005 4Runner AC system anemic? (1 Viewer)
Meatdawg
NM
The AC was blowing about 50-54 degrees out of the vents and the compressor was constantly cycling. I replaced the compressor, condensor and expansion valve. Then re-charged the system. Now it gets to around 48-50 at best. My 100 series and a GMC Yukon I have all get down to 40-42 according to the same guage I use on the 4Runner. I took it in to a shop and they went over the entire system and said everything is good. I have heard from a few people that the 4Runner AC systems are weak. Does anyone else have this issue with any year 4Runner?
no.california S.F.O BAY AREA (EAST BAY)
When you installed the new compressor did you drain in first before installing? some of them comes full of oil for the entire system, did you replace the receiver/drier? i was suspecting that your system might be overfilled with oil. Did you use a machine to charge the system or just a pair of gauges?
Meatdawg
NM
@vipergrhd - Thanks for the info. The AC is still only getting to the upper 40's. I did make sure the compressor was empty before install, then I filled it.
The shop I took it to after I did the work used a machine to charge it up. I am going to look at a few other things this Winter and hope to get it down to good numbers like your come next Summer.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
