Hey fellas, hope is all is well and everyone had a good holidays. I haven't been on here very much b/c I've been out enjoying the heck out of my "LuxCruiser." since I got it back in October. I have not had any issues however, I am approaching my 185,000 mark on the odo. Which means it's time for the timing belt/ water pump replacement. I've also decided to do my heater T's and hoses as well. Toyota & Lexus both quoted me around $1,700 for the job, but I found a reputable mechanic near me who has serviced plenty a L.C's and LX470's who said if I purchased everything needed he would do the job for less than what stealership's are looking to charge me.
The timing belt kit I'm looking to purchase is going to run me around $380 off eBay and come with the following:
Does this kit have everything I need for the job to be completed? If not, what else am I going to need? I'm also wondering what other services I should have performed at this mile mark since it's going to be in the shop?
- TOYOTA GENUINE COOLANT
- AISIN WATER PUMP w/GASKET WPT800
- KP WATER OUTLET GASKET 16341-50020 (For water by pass joint, Not for water pump)
- AISIN/TOYOTA SILICONE GLUE SEALANT
- MITSUBOSHI TIMIING BELT TB298
- KOYO TENSIONER 13505-50030
- KOYO IDLER TENSIONER 13503-50011
- NTN HYDRAULIC TENSIONER 13540-50030
- THO 2 CAMSHAFT SEALS 90311-38065
- THO CRANKSHAFT SEAL 90311 - 43006 / 90311-A0001
- BANDO/MITSUBOSHI SERPENTINE/DRIVE BELT 6PK2240
- GATES RADIATOR UPPER & LOWER HOSES 21660 Upper + 22491 Lower
- TAMA NTCL THERMOSTAT 90916-03100 / WV64TA-82A
- THO THERMOSTAT GASKET 16346-50010
