Hello everyone,
Last month I went wheeling in Big Bear after the snow they had, I went through a mud hole that caused my alternator to fail earlier this month. I ordered a high amp alternator and installed it, and everything has been fine since or so I thought.
This past week, I decided to change my diff fluids because I heard some humming noises and thought water had gotten in. When I opened the rear diff fill plug, the fluid looked clean and was dripping out, so I did not change it. I noticed a leak on the transfer case, so I drained and refilled it and added AT205. The leak is now gone, and the magnet only had sludge, no metal flakes or anything shiny. I also greased U joints until grease came out and slip yoke (not enough to move it) to avoid stressing the driveshaft.)
When I went to drain the front diff, the drain plug was extremely tight. To avoid stripping it or causing damage, I sprayed it with PB Blaster and let it soak.
Within the past few days, the humming noise got loud on the freeway from the front. At first, I thought it was dirty front diff fluid or possibly wheel bearings. On Sunday, while driving on the freeway around 70 to 75 mph, I heard a single clunk or pop and immediately slowed down. After I exited, I started hearing clunking at low speeds. It happens from barely moving up to about 30 mph. I thought it might be my U joints needing grease, but greasing them made no difference. The clunking sounded like it was coming from the rear, almost like something was hitting as the tires were turning.
I went ahead and repacked one front passenger wheel bearing thinking I was going to open it up and see dry bearings. The bearing looked great and still had fresh grease throughout, with only a small amount of dirty grease. After the test drive, nothing changed. I also went up 2 snap ring sizes for the CV. I have the slee tool ordered to grease the needle bearing not sure if a needle bearing will make clicking noise and humming.
I then drained the front diff fluid and it was black. When I inspected the magnet, I found a few very small chunks stuck to it, maybe 5 to 8 pieces. I refilled it with fresh fluid, but there was no change in the humming or clunking still the same. I am still thinking the noise is coming from the rear.
I took it to a friend who has access to a lift. With all four wheels in the air and the center diff lock engaged, I pressed the gas while he listened underneath. He said the clunk is coming only from the front diff. Nothing from the rear or transfer case.
I have zero vibrations in the cabin, which is why I do not think it is U joints, even though I already have front and rear U joints on order. My CV axles are OEM and have not slung any grease. I do wheel the truck, but I am not doing hardcore crawling or spinning tires like crazy to shock the diff. I never heard grinding noises from the diff even now the truck drives fine , with no grinding. The only issues are the low speed clunking from the front and the front end humming, almost like I am driving on mud terrains. For reference, I have less than 2k miles on my Falken Wildpeak AT4 tires. They are 255/85/16.
When I purchased the car through auction it already came with armor all around and winch. So previous owners probably wheeled pretty hard in AZ. I am located in SoCal. Just not sure is it the diff? If so what parts can give these symptoms? or can it be something else
Any input is appreciated!
