Hello Everyone,
I know there are so many threads discussing AHC, and I have done quite a bit of research but couldn't find answer to my issue.
Thanks to so many informative threads, and the AHC maintenance video and cheat sheet by YotaMD, I replaced all four accumulator globes from IMPEX Japan, flush the lines with new AHC fluids that comes in the tin can. I cross leveled the vehicle (still not able to get it perfectly even, but at least within ~1/4" difference) and got the front pressure in spec by cranking the torsion bars. I still need to get a new pair of rear springs to lower the rear pressure. The ride quality is totally different now!
But here is the issue I've noticed, the issue was present before and after all the above works were done. Every time I drive over a moderately height speed bump, the driver side would ride much smoother than the right side. It feels like the passenger front side would bounce off the speed bump and then almost drop off the edge when getting over the bump, and make a louder/harsher thump noise compare to a softer thud like the rest of the tires. Also, when going over a pot hole, the passenger front seems to right rougher than the rest.
I have read again and again that the actual shocks on the AHC suspension generally is not a source of suspension issue. Could it be the torsion bar crank rate? I did have to crank the driver side way more than the passenger side when I tried to cross level. What else could be a possible issue?
I do have a torn CV axle boot on the passenger side. Could a worn CV axle cause this issue? Also, when I turn either left or right, I would occasionally hear this low pitch grinding noise with vibration from either or both wheels. Took it to a local mechanic who used to be a master mechanic for Toyota and works with a lot of cruisers, he replaced both bearings, steering rack, lower ball joints. He also checked the upper ball joints and found no issue. Could all theses be related to the CV axle/suspension?
I'm just at a loss at this point after all the repairs and work, and still can't diagnose or fix the issue.
Thank you all so much in advance!
