For Sale 2000 LC, 140k mi, OME, Slee skid & bumper, winch,....$13,900 (1 Viewer)
For sale is my 2000 Toyota Land Cruiser 100 series. This Land Cruiser is in wonderful condition as you can tell from the pics. I am the 4th owner. Previous owner kept it for about 3 years and only certified Toyota technician worked on it. Drives flawlessly, tight, no rattles. I am including full details below including main features, service history, known issues, price etc. It's a great solid truck and hard for me to let go but life gets in the way. Hope it goes to a good home.
MAIN FEATURES:
140,000 miles (increasing as I drive it daily)
Timing Belt & Water Pump done @ 95,000 miles (documented and confirmed)
Garage kept
No leaks, no drips
Clean CARFAX, which I have available at hand. Shows NO accidents, 3 previous owners
NEW brake pads and rotors all around. New front brake calipers.
New exhaust pipe, muffler and tail pipe
New battery
New Alternator
Freshly serviced with oil change and filter
Emissions passed November 2015, good for 2 years until November 2017
VA Safety inspection passed last month
Great condition, interior is amazingly good.
Maintenance records available
Aftermarket stereo with Bluetooth connectivity
BUILD ADDITIONS:
Slee Off road "Blueberry" front bumper
2.5 inch Old Man Emu medium load lift kit
Slee Offroad Front Skid Plates
Slee Offroad Intermediate Guard
Slee Offroad Belly Plate
Warn 9.5 xp-s winch with synthetic line and hawse Fairlead
SERVICE HISTORY:
I have many service records at hand out of which some important service history is listed below:
August 2016: Wheel Alignment done
July 2016: Replaced upper and lower ball joints. Replaced rear right bearing+seal
April 2016: Four brand new BFG TA KO2s installed
March 2016: Undercarriage rust prevention and coating
March 2016: Emergency brake adjustment done
02/06/2016: Engine oil & filter change
01/29/2016: New brake pads and rotors all around. New front brake calipers.
11/07/2015: Emissions passed. Valid for 2 years.
11/04/2015: New Bank 1 Sensor 2 Oxygen sensor installed
11/21/2014: @132,366 miles. Oil/filter change. Pro clean Interior detail, replaced left front CV boots
06/17/2014: @126,090 miles. Oil/filter change. Replaced left+right rear wheel bearing assy's, replaced all seals and retainers, installed new stereo, replaced left+right front axles, replaced front differential mounts
04/23/2014: @123967 miles. Replaced left and right front sway bar link assy's, perform alignment
12/31/2011: @109837 miles. interior/exterior detailed, oil/filter change, air filter change, performed comprehensive check out, replaced cabin filter, cleaned and dried cv boots
08/25/2010: Replaced front brakes, rotors, wheel bearings, oil/filter changed, topped off fluids, brake fluid flush, replaced battery
05/28/2008: 90,000 mile service including Timing Belt, Water Pump, Spark Plugs, Coolant, Transmission + Motovac svcs. Air and Oil filters, Rotate and balance , Adjust brakes, Front brakes and rotors done.
12/22/2006: 80,000 mile service including oil/filter change, rotate tires, lube door hinges and propeller shaft. Inspect brakes, suspension and steering, top off fluid level, check belts hoses, lights, heater and AC system.
03/24/2006: 75,000 mile service done including engine oil/filter change, rotate tires, adjust brakes, lube door hinges and propeller shaft, replace air filter, inspect trans, diff and brake fluid, inspect suspension, steering, exhaust and drive line, top off fluids.
TITLE:
Title in hand and in my name.
I am a private owner. Serious buyers only please.
KNOWN ISSUES:
Sunroof doesn't open. It was like this when I bought it. Haven't looked into it.
Rear left door handle broken with some blemish
PRICE: $13,900
CASH ONLY.
Thanks.
Located in Northern Virginia .. VA/MD/DC metro area.
The rear left door handle works just fine. No odors inside, the lift was installed by previous owner a couple years back.
Pls note the vin# below if you want to run carfax.
VIN : JT3HT05J5Y0097028
I have the carfax from a few months back. It's clean, no accidents, confirms the previous owners and mileage. PM me if you would like to see it.
Update:
1. I plan to address the minor surface rust in pics above by a very professional place. Will first eliminate the rust and then do an under coating backed by a lifetime warranty. I don't think it will transfer to the new owner though but This will be added value and peace of mind to the new owner and I could provide the paper work. Will post pics after the job is done :) Asking price will remain the same.
2. I forgot to mention in my first post, I have also done a detailed service of the ebrake/hand brake system. It didn't use to hold well but now works perfectly.
The under carriage treatment is done (professionally) and looks like nothing is happening to this truck for another 15-20 years! Cost was $635. It wasn't in a bad shape to begin with but they did a great job with a lifetime warranty and the good news it is transferable to one new owner after me (but not further afterwards to second/third owners).
Great solid UZJ100. $13,900
Just installed four brand new BFGoodrich TA KO2s. Still driving it daily. Love this truck even more!
Willing so sell the skid separately?
Do you have pics of the underneath after the service? Do you know what piece to order to replace the rear door handle? Pics of the truck with the new tires?
