Interested in the front seats.. maybe the second row depending on condition.
Is the fuel pump control / relay in the left rear 1/4 panel still available? part #89570
Abs ecu part #89540-60160?
Ac control for the rear passengers
Seat belts if still working please pm price
Is the brake master/abs pump still available?
Are the front CV shafts in good condition? Any slop in the front hub flanges? How are the bushings on the rear upper control arms? How are the bushings in the rear lower control arms? Consider selling the APPS separately from the throttle body?
master window switch still available?
do you have the little black hole cover for where the rear diff lock switch is on the 98 and 99? I drilled into my cover for a switch and don't like the look so I want to replace it.
I'd be interested in the ABS/Master Cylinder/Brake booster assembly. Are parts still available?
Front fender liners?
Is the electric pusher fan sold? Thanks
Interested in the drivers-side door actuator
I was under the impression that 100's came with an electic auxiliary fan.
I am looking for a rear passenger door panel and any wood trim pieces you have that go around shifter and on door armrests ( window controls)
Thanks
