Parting Out 2000 100 Series Eastern NM
Are the front CV shafts in good condition? Any slop in the front hub flanges? How are the bushings on the rear upper control arms? How are the bushings in the rear lower control arms? Consider selling the APPS separately from the throttle body?
do you have the little black hole cover for where the rear diff lock switch is on the 98 and 99? I drilled into my cover for a switch and don't like the look so I want to replace it.
Is the electric pusher fan sold? Thanks
I was under the impression that 100's came with an electic auxiliary fan.
master window switch still available?
I'd be interested in the ABS/Master Cylinder/Brake booster assembly. Are parts still available?
Front fender liners?
Interested in the drivers-side door actuator
PMs Sent!
I am looking for a rear passenger door panel and any wood trim pieces you have that go around shifter and on door armrests ( window controls)
Thanks
interested in the following if still available - shipped to 20141:
drivers side switch panel (left of steering wheel: mirrors, rear vents, blank inserts, etc)
2nd row cup holder
2nd row seat belts (if tensioners work)
power antenna motor
center console trim (surrounds radio/climate control)
driver door window/lock switch panel
license plate lights
plastic engine cover
engine fuse box cover (provided fuse diagram is on cover)
Thanks!
Mike
