You can’t really be “off” on questions, which is exactly what each of the comments above introduces into the thread discussion. And you can’t really be “off” when “ease of mounting” is specifically introduced into the question and is then confirmed by the answer.
The BB skids look awesome, and the different materials options are a brilliant solution for different use scenarios. The questions above are just trying to explore the different pluses/minuses or different skid/shield solutions. That’s all. If OEM/BB/ARB skids were perfect solutions, we wouldn’t be having this discussion.
But the question about welding & potentially reinforcing the three factory metal shields still stands, and curious if anyone has done that mod and would mind sharing reinforcement lessons. Might be a more attractive option for some folks.
Next, all frames flex, expand/contract across different stress angles, temp curves, etc. Even minor “plating” (welding a steel corner to a frame-crossmember junction) of a ladder frame has stiffening effects, irrespective of frame design. Yes, LC200 frames are solid beasts that can support semi-truck loads. But there’s a reason the LC underbody doesn’t look like the Audi, and, as was pointed out, it’s not just about cooling. Right now, there’s a separate thread discussion taking plate about shielding solutions for the running board areas for LXs — to serve as possible de facto sliders/shields for the AHC accumulators & wizardry. These are mods that should be actively supported & incubated because they lead to more overall protection & less overall drag.
The point isn’t to say that we should be moving towards a more fully-enclosed underbody (access has benefits) — but to figure out how to achieve more shielding across a larger surface area — with reasonable expenditure of time & $$$.
The easiest DIY solution seems to be to weld the metal pieces together and to potentially reinforce them (meaning strengthening with more sheet metal or merely closing up some of the potentially unnecessary holes/crevices, which are mud/dirt/moisture accumulators. Before adding this to a long to-do list, asking if others have done this, and if so, pluses and minuses. Plus trying to learn from other creative solutions to this problem.
Don’t take things too literally. The “off” statement wasn’t directed at the question, it was directed at your possible answers for those questions. Your possible answers were off. It’s a nicer way of saying, “no man, that’s a terrible idea”
Off-roading is a rather simple premise. If something breaks, replace it with something stronger that doesn’t just move the breaking point to something more expensive. If something doesn’t get broken, then leave it alone if you want to save money.
You won’t find anyone reinforcing stock skids.
Do you know, and have you fabricated and welded before? Serious question. Because adding real strength to the curvy OEM skids will be quite intensive and expensive to the point where just starting with a new design is cheaper.
And yes all frames flex, but the 200 flexes so little that it’s not a factor. So don’t take one questions answer, and apply it to another question. The holes are for installing, not flex. Two separate reasons, not interchangeable answers. Axle housing flex, but you don’t see anyone talking about it because it’s just not a factor on what anyone is using this for. Drive a stock 200 up an RTI ramp, then do it with full skids, sliders, and bumpers. You’ll have the same score, because the frames don’t flex enough to change anything.
If you know how to fabricate, then why are you asking, go out and start making something and share it. That what helps the group.
You get a lot of flak on here for being a troll. It’s because you bring up questions that make everyone think one of two things:
1) he has no real world experience and over thinking everything
2) he is just causing arguments
Which is it? I hope it’s just #1, in that case, we’ll get you up to speed... one day.
Not being mean, far from it, just letting you know what we see and not sugar coating it.
