Looking at moving up to a new 200 LC from my current 2004 LC. This would be my fourth LC...'91/'94/2004 with just about 500K cumulative miles.
Curious what previous 100 series LC owners have found they "dislike" with the "new" 200 series??
Couple I can mention...
1) The seats that do not "come out" w/o some level of taking things apart. I do not need or want the third row seat and have had my current set double bagged in my attic since the day I brought it home.
2) I like the LC size and ride and am a bit concerned that the 200 series is a bit larger. Any observations from those of you who moved from a 100 series to a 200 series?
3) I am hoping the running boards are as easy to take off as on the 100 series and that I can also upsize the tire diameter about one inch...which is what I did on my 2004?
Other than that I primarily use my LC as a personal vehicle with moderate weight trailering and some moderate off road use...mostly vehicle size roads/trails where you really just need a little clearance and maybe occasionally limited slip or AWD may be handy. My wife claims I only use the AWD when she has to pull my garden tractor out on one of our fields or trails
Is the new size a noticeable change? Negative? Also, BTW...I like the look of the 100 series but that his just me...I also liked the look of the 80 series better than the 100
Thanks guys...I appreciate your input...TomR
job - very easy. If you are only taking the seats out once and either never using them or installing drawers, then it really isn't an issue.
