200 Series Engine Swap Options (6 Viewers)
Ever since then, I always have the worst-case scenario in mind when making a purchase decision. So if all other factors and pros/cons even out, I may take engine swap into consideration of the final decision, in case if one costs a lot more than the other (for same engine swap, because other options like LS swap may not be feasible in Cali so far). Unless the law changes and CARB goes away...
The Tundra / Sequoia engines are cheaper. Not by that much, but they are.
More importantly they are more plentiful simply due to higher sales volumes. There are stories here where there's been many many months of downtime while the owner searches for the right 200 motor. I'd assume that going with the Tundra / Sequoia there will be less downtime and many more motors available (with a good warranty from a reputable yard).
Buy a late model (fill in the blank) from Carmax, paying a 10-15% upcharge. Spring for the extended warranty. Hug your wife everyday.....
Would be interesting to hear your engine explosion details......
Bought what appeared to be a super clean 2011 LX570. Spotless undercarriage. Engine appeared totally dry. Ran great. Decided to forego a PPI (smart) to try and make a deal on the spot because I thought it would go quick at the price point. Drove it home no issues. Was going to have my mother in law drive it for a few weeks while she was in between cars. She gets it home after a 3 hour drive and says its leaking some oil. I think okay maybe something minor, have it towed to a reputable shop. Dude tells me its literally pissing all the oil out the back of the motor. We're thinking some sort of catastrophic rear main seal failure which seems bizarre. Open it up and someone didn't torque the torque converter bolts down well, they backed out, hit the flywheel, cracked the block. 2 weeks into owning the thing I'm down a motor.
Would a PPI had even caught this?
Probably not in all honesty, such a bizarre failure point.
Any indication of transmission replacement in the service history?
Nope, not even any recent transmission work. Had an alternator done like 20k ago and that was the most recent service.
That sucks to hear. Definitely not a common failure on this platform, hence my suspicion it had been worked on.
Tragic, I’d love to know what happened there. You seem to be handling it far better than I would.
I'm a few months into the grieving process. I couldn't even be mad at the guy that sold it to me because I genuinely think he had no idea either, we had a few conversations and I think he felt bad but ultimately there just wasn't much to be done about it. My best guess is someone did some transmission work on it before he ever bought it, didn't document it, and I was just the lucky winner of the ticking time bomb. Still on the fence about trying to swap it myself or just biting the bullet on the labor but I like this damned rig too much to just sell it as a shell.
Similar situation here in my case. Stay tuned....
Yup. Kind of a leap of faith......but.....
not likely I have done a great amount of PPIs on German vehicles and aside from indications i.e. shiny bits or something else I can see or hear it is invisible unless the trans mission bellhousing has an inspection plate which most don't anymore.. regardless of torquing they get a small bit of lock tight if the new ones don't have it already added to the threads.
