200 grille soon available
kelly saad
Supporting Vendor
Flagstaff Arizona
Thanks to another generous Land Cruiser owner, I am able to produce another grille, now for the early 200. Just finished the CAD files for the 08-15 Land Cruiser grille. Looks pretty straight forward, I do not see too many issues with the prototype not fitting closely. There will be some adjustments for sure, but I should be close on the first try. Sounds like Easter timing for the test fit, so we shall see.
Built from 12 gauge steel, it will probably weigh about 16 LBS. These are tough and built solid.
I have attached some examples of the design. There are two versions, 1 piece (smooth across the front, more simple) and a 2 piece (this has a bolt on panel on the front). The 1 piece is the bottom one in the image below. I have many air flow and emblem options. Custom light openings are also optional. Any style of grille on my website can be made in this model. Check out website for more examples. Price will be $500 for 1 piece and $525 for 2 piece.
www.landcruisergrilles.com
kelly saad
Supporting Vendor
Flagstaff Arizona
That is the issue, the radar sensor. I would be happy to create a location for it, but wouldn't guarantee that it would function properly. That would be up to the buyer to make sure it is adjusted properly. What year did they begin offering that? I kinda figured it was only on the 16+ but I am not that familiar with the 200. Looks like that began in 2011?
M1911
On the beach
My 2013 has a radar sensor.
Texas
Love where you’re going with this. But, If you are able to incorporate something like this into the product (ABS plastic grille panel) it would broaden your market, because (IMHO) some folks may not want to give up their cruise control. I placed a relatively small metal Toyota emblem on my black plastic after market grille and it disabled the cruise radar, hence its whole function. At first I didn’t mind, but after a while it bothered me enough to get the plastic badge.
That all said, if it’s bad a*#, I may forgo the cruise once again :)
Universal Black ABS Plastic Racing Hex Mesh Honeycomb Grill Spoiler Bumper Vent Amazon product
Utah
The '13+ LC had radar cruise.
If you make a mounting provision for the sensor, it may work fine through the honeycomb.
Keep in mind there's some gear behind the grill that you'll need to clearance for if your mounting big ass lights in the grill.
kelly saad
Supporting Vendor
Flagstaff Arizona
Thanks everyone. I will look into the radar thing, im sure it can be done.
All my parts are 12 gauge steel, that's just all I work with. If this will work for some vehicles, then cool. If not that's ok too. The light openings are just an example, but thanks!
scottm
Below the bridge
How about using perforated polycarbonate or PVC sheet instead of 12ga steel? Send your .dxf to any waterjet place, and it will be fast and cheap, compared to the steel you have to deburr and Powdercoat.
kelly saad
Supporting Vendor
Flagstaff Arizona
Thanks for the suggestion, it’s a good idea. I only use 12 gauge steel though. I build all my grilles from 12 gauge, as I want them to be tough. Not really interested in using plastic. Perhaps I will consider it for the front bolt on panel if this progresses further though. I could keep the steel frame. Thanks!
Hammeredsole
Santa Rosa?
Yep, find a way to mount the front emblem/radar/front camera of the 13+ and it’s a definite buy for me. No mount = definitely no buy. Many will pass the same I assume. It’s just another cutout, should be that much more work. I’m not willing to give up functionality for looks.
kelly saad
Supporting Vendor
Flagstaff Arizona
I would feel the same way. We are looking into the option of using the sensor and camera on the newer models. If it doesn’t work out, then these will only be for the models before that. Will update here as the progress continues.
Beaverton, OR
I'll fall in line with these guys. The radar cruise on my '14 is one of my fav features, especially on long trips. If you get that solved then I'm definitely interested.
kelly saad
Supporting Vendor
Flagstaff Arizona
I understand, Im happy to make this work. I'm sure it won't be too difficult from what we have been looking at so far. I am just concerned with the liability of the whole thing.
kelly saad
Supporting Vendor
Flagstaff Arizona
Parts were cut for prototype and I built it last night. I had to tweak a few things with my parts, made adjustments and it fits great. I don’t have any pictures to show yet, as I only built a frame and face frame to fit and adjust. I will make new CAD files based of these parts and cut a new complete grille for photos. Might take a while though.
gaijin
GOLD Star
Is there any provision for mounting the camera found on 2013's?
TIA
kelly saad
Supporting Vendor
Flagstaff Arizona
TIA
We have been discussing options for the camera, but I am not moving forward with that yet until I see how this first one goes. Also, I am a bit worried about the liability issue building a grille for a vehicle that has the camera and radar.
