2" Analog Dual Voltmeter
TreadingLight
"Overlanding is Sh*t"
Central Valley, CA
To conserve dash space, I'd like to have a dual voltmeter in a single 2" round gauge. Dual gauges are not uncommon but for some reason analog dual voltmeters are.
I have only found two, both Australian, and both quite pricey. Ideally I'd find a $50-100 autometer-like gauge from a US vendor.
Does anyone know of any other analog dual voltmeters for a standard ~2" / 50mm round gauge pod?
I was recently looking for the exact same thing and was only able to find the very expensive Redarc meter. I ended up buying a dual voltmeter from Amazon, the smallish round kind that you usually see with one voltmeter and a couple USB charge ports. I removed the guts from the shell, did a small mod I found here on Mud so it would only turn on with the key, and then mounted it in a switch blank on my dash. Probably not the exact answer you wanted, but it’s another idea for you.
Here’s that thread I mentioned - some good suggestions for dual voltage gauges in the beginning, and my write up is the last post.
