This is my Hail Mary post to get this figured out. I have A 1990 HZJ73 that I swapped The 1HZ with a 1HDT engine. Supposedly the BEB and injectors were done on the 1HDT.
The engine will turn over but not start. The engine will start with starter fluid but obviously dies right after. First thought was air in the fuel lines so I’ve spent 3 days working on that to the point that I dont Think that air in the fuel line is the issue.
When I loosen the injector nut and crank the engine, there’s no fuel.
When I loosen the bolt at the top of the injector (holds the nozzle leakage pipe) and hand pump the primer, fuel comes out of the top of the injector.
So now I’m at the point that I’m wondering why there is no fuel coming from the IP to the injectors but I’m stumped. Does anyone know anymore trouble shooting checks? Or does anyone know why an IP wouldn’t be sending fuel?
Thanks in advance.
Thanks in advance.
