1hz primer
Bowen
My primer is sucking air after failing i replaced with new primer filter sensor and hoses when i prime it up it goes hard then loses prime hellp
You're still getting air in somewhere.
Loose hose. Bad connection. Cracked old hose. Bad o-ring
Did you change all hoses?
Did you use the correct size hose?
Did you use Toyota hose clamps? Or cheap worm drive clamps?
Are both o-rings on the filter good? If not lubed when installing the filter they can twist and deform.
