Thanks!
This post includes a line showing fuel consumption as RPM's increase (see the bottom line on the graph):
3b twin scroll turbo
There is always going to be that trade off between speed/time and fuel economy. For economy I try to keep RPM's at or just under 2000 which looking at the graph in the other post would be about right.
Is the lowest line on the above 1HD-T dyno chart also fuel consumption?
I got my best mileage to date on the weekend, travelling about 95km/h on relatively flat highway, no AC, cruise control on, 2.5" lift, 33" tires, stock gearing (4.11 I believe), auto. Worked out to 20.8mpg (US). I usually would travel about 113km/h on a 100km/h speed limit highway, but I was part of a convoy.
Anyone know what sort of economy the 1HDT in the 70 series gets? I would expect it to better than in the 80 series because of the option to run 2wd? Also lighter vehicles?
Im guessing this is mainly due to camming choices by Mr. T for each which would make sense as the Hz is likely a more Mine-oriented duty design vs hdt which likely designed for higher speed/higher power hauling duties.
Isn't the 1HZ really high, like 21:1 or something?The reason for the 1HZ extra power with a turbo maybe in the higher compressions ratio 18:1 vs 16:1
Yeah, 1hz was 22.7 pre 98, then lowered to 22.4 post 98. 1hd-t was 18.6. This is why the 1hz lugs much better down low.
Agreed. Its all about compression.
1hz pulls like a fourteen year old with a Victoria's Secret catalogue from basically idle.
1hd-t in standard tune doesn't really get cracking until 1800rpm-ish.
