Scratch Fred Holmes
Okanagam fuel injection in Vernon
It will be cheaper than dealing with Raj
Western turbo have rebuilt 1hdt injectors for me before
Is still running fine in a custimer's hdj,truck came in misfiring,customer put too much oil in the engine,ive to rebuild the engine,two injectors have missing tips,2 or more pistons were missing metal on top.
Western turbo rebuilt the injectors.
Ended up putting new sleeves on the block,all new pistons n bearings n gaskets from engine Australia.
Yes there is, Gturbo, Diesel Central and XXi to name a few do them, but there's no need for them until around the 27psi intercooled mark and I mean, I make 154 rwkw at 25psi which is more than 100% over stock which is a massive difference and for most people, probably enough powerAre there really no performance injectors available for 1HDT?
Stock is 122kw for 1HDT. What am I missing?Yes there is, Gturbo, Diesel Central and XXi to name a few do them, but there's no need for them until around the 27psi intercooled mark and I mean, I make 154 rwkw at 25psi which is more than 100% over stock which is a massive difference and for most people, probably enough power
122 kW on an engine dyno with no water pump, alternator, vacuum pump etc etc. So, by the time it gets to the rear wheels, in the truck, it's driving accessories, and then the power lost in the drive train , it's generally accepted that around 30% power is lost through the drivetrain, more with larger tyres. The figures I have show about 37% loss in an 80, although that's all relative as all dynos vary from each other.Stock is 122kw for 1HDT. What am I missing?
rwkw at 25 psi, 21:1 AFRs on boost. All my figures are on 285 / 75r16 A/Ts at 38 psi
I don't recall, it would have been in winter, so wouldn’t have been real hot. I'll see if i can find the dyno sheetsdid you recall ambient temp and relative humidity the day you test it ..?
21:1 it's damn good for those numbers ..
