So on this one, it is around a 2002 gen. The bores were out by a thousand or two, my machinist felt we could run it with fresh rings and light hone but I said nah so we bored it and got new OEM .50 over pistons. As pictured above we had tops and skirts ceramic coated.
Typical head clogged with soot and gum/gunk, Euro spec EGR equipped FTE. We went all new valves, springs, stem seals, ect on the head. Took 2mm off head bolt seats under cam for the FTE ARP’s and to feel comfy about that clearance vs any clearancing of the ARP’s. I can’t recall if the clearance out of the box under the cam, iirc there is something in the instructions about this, not running the washer or something like that. We just take the head stud seat down 2mm under the cam and all is good to go.
Crank only needed a polish.
If you guys like the “build outs” I will keep posting on this one? Or we can stick more to the tech side and the original point of the thread?
Cheers
