Hi Mud I have a 1998 470 with a bad engine . what years fit it ?
Thanks
Thanks
I'm curious, what's happened to your 98 engine?Hi Mud I have a 1998 470 with a bad engine . what years fit it ?
Thanks
Based upon?Tundra engines have more power than Lexus(s) (imho).
all 4.7 engines out of any toyota product will work (pre 2003) for sure... some after... you can read my post as I have done this 2x... I have had good luck with engines off ebay most go for less than $1000, most salvage yards will remove them well including the wire harness (which you won't need but nice to have extra connectors) you will have to use your throttle body... but you still need to remove the intake to hook up the harness to the starter... (good time to check the starter) you will have to use your oil pan and your oil filter housing, and your exhaust manifolds and engine mounts... ask the seller of the engine for the VIN of the vehicle it came from to confirm the miles, most any engine under 150k should be fine but less is always better.. doing the full timing belt service while the engine is on the stand takes less than an hour... also a good time to replace rack & pinion bushings with engine out... I'm slow as dirt and working alone I'd guess 16-20 hours of labor... but I do a ton of cleaning and making sure everything looks like it came from the factory... also... GET the engine from a SOUTHERN or rust free area... I've seen engines from up north that look like they were underwater half their life... the engines I got looked all but NEWHi Mud I have a 1998 470 with a bad engine . what years fit it ?
Thanks
Thank you everyone
My truck has a bad knocking so that is the reason I'm looking into a new (to me ) engine . I also plan on doing the timing belt and gasket while I have it out .
How hard is it on taking the engine out of the truck ?
I have heard that and that the rods are true forged rods in an LC.... I can only say I had to oil pans off all 4 engines 2 donors (non LC) and 2 original LC / Lexus and every casting mark and web were exactly the same on both... it's my understanding that toyota has a patent on a powder forging process it uses on the rods and all the rods are made in japan even on US built engines... hard to believe that they would have 2 different quality parts that bear the same part number..... piston failure is so rare in any modern electronically controlled engine with knock control it is all but a non issue... coupled with the modern metallurgy and controlled casting environments that unless you are running compression ratios above 12 / 1 it is unneeded... the reason these engine have such long life in all their forms is due to this and the proper mating of materials at the controlled clearances... it's a way over built engine based on size, bore/ stroke / rod length/ bearing size/surface area... I've been building racing engines since I was 12 years old... yes alone... 12000+ rpm engines... and this toyota engine is the first bone stock engine I've ever looked inside and said... "damn that is pretty" on the blown engines I had to get out my micrometers and measure stupid things like crank thrust and rod clearance... one of these engines had 305k on it and one had 172k on it... and both were still within specs... you could still see HONE marks on the cylinder walls @ 305kSo is the rumor true that LC 4.7's were forged Pistons? Maybe a little better built than other application 4.7's?
Sent from my iPhone
Based upon?
Maybe? but hard to tell if they program the ecu for the weight and gearing of the vehicle... I would assume toyota would... there is nothing in the long block or the injection system that would make any one application of the 4.7 more powerful than the other... unless one has different cams... and I have not heard of any one cam being different than another... and again I would doubt that Toyota would have more than one version of the same basic long blockThe iForce is strong with this one.
So after checking everything in the engine bay , it happen to be a water pump making a clunking noise I won't be needing An engine for now only a timing belt , water pump etc
