Builds 1996 KZJ78W Land Cruiser Prado (J78) Build (3 Viewers)
Ha. 26Z color code, that’s actually dark emerald. When I do a polish and wax with the buffer, dust doesn’t stick!
You need a dustier/muddier road.....love the steering wheel
And taller/narrower tires.
Fat tires are rough on wheel/bearings/etc
Due to age you should seriously consider pre-emtively R&R front and rear axle seals/knuckle bearings/wheel bearings and be done with it
Its not difficult, just time consuming and can be done with simple tools
Bringing this one back to the top.
I ordered the Dobinsons Stock Height Restoration kit and it's on the way as we speak. I like the current height on my J78 but the suspension is pretty clapped out so I'll just knock this one out. I think maybe an inch of lift would be just right so I'm hoping it's adjustable and/or will settle in. I do not want 2" of lift on this grocery getter.
I also ordered a replacement OEM grille from Japan. It looks fine from this angle but when you get up close, you can see the chrome finishing wearing off at places.
I'm considering replacing the exhaust system which is pretty rusted at this point and sounds like it might have a leak or a hole.
I'm inclined to keep the factory alloys but I want to get a quote on powder coating them the same color for a refresh. If it's reasonable, I'll probably go in that direction.
Tires are in good shape so I'll probably hold onto them for another year or two.
Any suggestions, gang?
@Tsvigo is that an air, to air or water? Did you need to scoop the hood or did it fit flush on top of engine? I am currently planning my IC install. Thanks
Air to air, no it does not sit flush. Will be sitting higher than standard Prado body. Then I would be recommending doing a front mount intercooler is better.
