Hey Guys,
I've been posting around here with different comments on my swap, but I figured I'd make it official and put down the info that I'm finding while going through this swap. I'm about halfway done at this point but here's what I got so far...
I decided to do the swap not for the 5.3 but for the gearing option of going to dual t-cases with the np203 and the split case. It gives me a 2:1 and 4:1 options which should be nice. The added benefit of the swap was more power, stronger trans and losing 400lbs up front.
No issues with pulling the motor.
I picked up my engine and trans from an LKQ junk yard near me in blue island. $1600+tax for an '03 Yukon XL 5.3 and 4l60e with about 94k mi. on it. Nice thing is it has a 6.mo warranty.
I ordered the np203 to split case adapter from Jerry at from Colorado off road and had it shipped to off road design. I ordered the np203 from off road design and they sent me a rebuilt 203 with the adapter installed which was nice and easy. The 203 was drilled and tapped to bolt right on to the 4l60e with no adapters.
I picked up a split case from Gumby (Thanks again!) and put those two together. They make a nice little pair behind the trans.
I cut off the old engine mounts ground everything flush and welded on a set of dirty dingo street rod adjustable mounts.
From warpdriv's thread I picked up a bunch of info. I ordered the block hugger hooker headers from summit racing and those worked out great. They tuck very nicely between the frame rails. I also picked up a 1999 camaro oil pan for clearance with the front axle. I also went with a wiring harness and other bits that needed to go along with that (TAC module, gas pedal for fly by wire system and 2 position brake switch) from Jon at PSI. Great guy by the way. He sent me all the bits I needed and programed the PCM so everything should be peachy keen.
Spent the earlier part of this weekend finishing up the cross member to support the trans. Thanks to 4rnr on that one. We used the existing cross member to start with and then used 2.5" 1/4 wall square tube to build a mount that bolted to bottom rear of the 4l60e. Should be strong as an ox. I'll throw up a few pictures soon.
At this point, I'm going to have to have the rear drive shaft lengthen and front shortened by a few inches. Who knew going to dual t-cases would be an overall shorter drive train...
It's close as far as clearance goes between the flange on the front axle and the oil pan, but it should be ok.
Projects for this week are to take care of the drive shafts, start getting some custom power steering lines made, and start working on the fuel system and get shifters ordered. I'm going to go with an art carr shifter and set up some custom linkages for the t-cases.
I've ordered a tt supra pump to drop in the tank and I'm thinking of running a corvette fuel filter near the engine instead of setting up a fuel pressure regulator as the filters are internally regulated. Not sure how that will adapt to the engine at this point as the 5.3 has a return and the return with the corvette filter is on the filter. Anyone know how I can make that work?
That's basically where I'm at. I'll post up some pictures in a bit. Gotta head out to dinner with the in-laws.
