Hi folks,
Heading down the road of an eventual turbo solution but first I am going to replace the stock ECU with a Haltech elite 2500, basic harness, wideband O2 kit and 6 HT-020114 high output coils with built in igniters. Will drive around for a few months and then save bucks for a witts-end turbo kit.
ECU. I Spoke to the local wiring guy and he said I have, broadly speaking, 2 options, piggyback and use some of the ecu but leave idle, air cond, dash, etc or full harness rewire.
Either way, I want to go full sequential. I also have an autotrans and injected liquid vapour gas(LPG) to make work
I think I want to walk in to his workshop with a general spec of what I want so as to not be overwhelmed by his own views.
What better place to ask this question? I have already scanned the web for ideas and spoken to the haltech techs and it seems the consensus is to use some of the existing ecu and some of the haltech for other bits. I will also be wanting to use the 4D mapping for both LPG and 98ron petrol. Engine was rebuilt a couple of months ago and turbo compatible pistons were added, otherwise stock.
Q1. What should I leave to the factory ecu and what should I switch over to the haltech?
Q2. Seems TPS may be difficult to wire to the Haltech. If I go the full rewire, can you advise on what "bits" will be the difficult bits?
I figure I will have more questions but at this stage I am not sure I know enough to ask.
Thx,
Thx,
