order a backup light switch for a 2000 5spd Tacoma. Lots of CDL info in this thread:
CDL Actuator Fun
This switch looked very familiar to me - I had done a 5sfe/S54 swap into an AW11 and the reverse connector (among just about everything else - and in that vehicle I payed close attention to NOT cut any body/factory harness to couple the body/engine harnesses) looked the same. Per Rock Auto it looks to be the same, and since it's just a simple on/off switch, resistance values wouldn't be impacted. Looks like $15.75 from rock auto. My guess is all FWD/MR cars with a 5 speed manual from about 91/92/93 (depending on model) up would be the same switch. Doesn't surprise me since it's easier/cheaper to use the same part across multiple platforms and not have to pay to re-engineer "the wheel", so to speak.
Nice job!! Yeah, this is looking like it's turning into a build thread...pics or it didn't happen!
You would think with having a nice camera on my phone plus having 2 DSLR's and a lot of lenses that I would actually document something...
The rear locker splines are corser and seem to always take longer to lock. Try locking the rear and do slow figure 8s in the dirt to see if it'll lock in.
This is where things get weird. I'm guessing testing lockers on dry pavement is a no-no.... most of my testing is done in my driveway (about 40-60 feet, I really have no idea) which is gravel.....
drove to someone's house for lunch after the above information was provided.... and was ~50 yards from her driveway. Threw it in 4L (CDL popped on), threw the locker switch on (front locked, rear did not) and drove slowly to her house.... It almost refused to turn right, and turning left it was fine with. That bothered me, so about 10 feet from her driveway I stopped, put it in neutral, turned the lockers off, then put it in 4H, then drive.... and the CDL light stayed on, ABS light stayed on, and the steering issue prevailed. Tried a few combinations, but pulled into the driveway to go on a walk.
Got back - and had to head home.
Same issue (even though in 4H and lockers off - center diff light was on as was ABS).... tried forward, backward.... so figured I would try to hit a bump or something, backed up, turned hard (out of the drieway) and "POP"..... lights went out, everything was 'back to normal'.
Got back to my house, and in the gravel driveway.....
put it in 4L and the CDL/ABS lights popped on.
put it in 4H and the CDL/ABS lights popped off
put it in 4L and the CDL/ABS lights did not pop on - put it in reverse (nothing), then neutral then drive - and it popped on.
switched the locker on.... and the REAR locked, front did not
turned lockers off, and they turned off.
turned lockers on, and the front hesitated, but turned on, then after moving a foot the rear locked.
turned lockers off, and the rear wouldn't let go
turned lockers on, and then off, and the rear let go but the front wouldn't
My guess:
1) the CDL switch is bad (I could hear the relays turning on and off like crazy), which my multimeter was already telling me
2) the rear motor is tight, needs to be pulled/cleaned
3) the components just need to be used a little bit, turned on/off regularly to get movement in them
4) maybe the diffs all need new fluid
As a side note - the plug wires arrived (been dealing with the diff's instead, lately) so I plan to do a compression test - then install all components (plugs, wires, cap, rotor). I have a sneaking suspicion the engine isn't original - or if it is, it's been pulled/rebuilt. I'll check the vin and mount bolts to see if they're marred (no smoking at all, not even at start up, strong oil pressure, essentially no leaks... and 291k miles....)
Ordered a keyless entry/remote start and will install that at some point in the future (I don't trust the key to be used that much longer, so I don't use it in the doors...)
