For Sale 1993 4BT Cummins Turbo Diesel Cruiser. Central Kentucky. (1 Viewer)
*SOLD* Central Kentucky (Frankfort)
$8,000 OBO
Life has a way of changing ones plans. I am at a point where I need to simplify a bit and focus my time and resources on finishing a major home renovation. I have too many vehicles and I had plans for this 4BT cruiser but need to let it go so I can get this house done. I may be selling my 94 with lockers as well.
I have only had the cruiser for about 5 months. I had plans to swap my locking axles and some other parts from my 94 cruiser over to this one and use it as a driver. I don't have the time to work on any of this or any other projects other than the farm and house at the moment.
This Cruiser was in South Carolina for 2 years, Colorado for 6 years. It is originally a Florida vehicle and was back in Florida until I bought it. It has been in Kentucky for about 5 months. I am driving it now as my 94 is running like a turd with some EGR issues, throwing a code 71. Won't hardly idle and tends to die. Plan on driving this Cummins while I clean out the intake and clean the EGR system up.
This is a great running cruiser and drives nice. The tires are older and I get a slight wobble in the steering wheel from time to time at higher speeds in a turn. Drives straight with a little wander here and there. She is no beauty queen but looks pretty good. Very little rust due to it being a southern truck most of its life.
It is a Proffitts Cruisers 4BT conversion from 2009 I believe. That is what I was told. The previous owner used it for a daily drive for about 4 years and said he had no issues with it at all. Very reliable. He is a MUD member. It starts up and runs and drives nice. About all I have done is put one new battery on it from NAPA and wash the outside and drive it. I did check the fluid levels. That is about it.
Some details from the previous owner below.
"1995 Cummins 4bta engine with 170k miles
KDP (killer dowel pin) on engine done
New style Heavy Duty 700r4 with diesel appropriate modifications. (Shifts perfectly)
Torque converter lockup on OD button.
Water to air aftercooler that runs on seperate cooling system from engine
Worst mileage- 14mpg Best mileage 18mpg
AC is like an icebox, even in Florida. Much colder than factory
33" Maxxis Big Horn Mud terrain tires with approximately 15,000 miles
Spare is the Dura Grappler- brand new
Slee 4" springs
Ome shocks
Double Cardan front shaft
Slee Caster Plate
Weld in front Panhard adjuster
MAF rear panhard drop bracket
Drives straight
All Slee stainless brake lines
new style slee headlight harness
Custom made front bumper with winch plate
Kaymar rear bumper with spare mounted, second post on passenger side. "Slam shut" modification
CDL/ pin 7 mod
Exterior is in overall good condition with minor scuffs/scratches here and there.
No accidents
I have only (lightly) off-roaded it once. Part of the reason I am selling.
Armrest modification for driver's seat. Volvo center console modification for cup holders.
Homemade dual tank system with factory dual filler neck. (Previous owner was still working on this, but all parts are present)
Dual batteries (one new)
Under hood start switch. Nice for bleeding injectors.
Vehicle is ready to run WVO/ alternate fuels using a "two tank system". (I'm not currently using this) Fuel is heated via coolant heat exchanger
Fuel pressure gauge, fuel temperature gauge, sub tank fuel level gauge on console.
No oil leaks or Blow by from engine. No puddles in driveway.
Engine runs awesome; starts right up every time. Puff of smoke from exhaust on start up and that's it. Very reliable vehicle. This is my daily driver. No issues at all. I drive my 5 year old around in this. Mileage is 334xxx and will go up through daily use.
The bad:
The factory radio kinda sucks, CD player and tape player do not work.
Front seats need repair or seat covers.
At some point, vehicle will need paint or liner, but completely acceptable for now."
As you can see it has a lot of nice mods and some hard to find parts (factory dual fuel filler neck). I will attach some pictures and videos as wall. The videos are not the best but they do give you some idea of how it drives and sounds. It is a lot of fun to drive and I had one compliment the second day I was driving it.
I am looking to sell it fairly quickly to get on with my renovations. Looking to get $8,000 for the cruiser. I will also be considering best offers but will be looking to get the full $8,000 for starters. Good solid and fully functioning diesel cruiser.
I do not know a whole lot about the truck as I have had little time to fool with it other than what I mentioned and driving it. Feel free to ask questions though and I will let you know all I know.
I did notice it does have LED interior lights so that mod has also been done. I has a lot of great mods and a nice build. The only gauge that does not work is the oil pressure gauge on the dash. It has a pressure gauge under the hood that you can monitor the engine oil pressures with. Previous owner could not get the dash gauge functioning. I have not looked at it. Fuel gauge works but sometimes takes a temporary plummet for some reason but it works. Trans temp gauge dances around a lot, not sure what is up with it.
Thanks!
Some shots of the front axle. Looks like the passenger side is leaking a bit. Didn't notice much in the way of any drips on the drivers side. It is moist at the bottom.
It has some dents and rust on the panel below the headlights and grill. Looks to have been some body work and paint maybe? Hood looks to have been painted as well.
It does have a plug for the heater for the engine sitting in the front bumper. I have not looked to see what kind of heater yet.
Nice Kaymar bumper and tire swingout. It does have some damage to the lift gate and has been painted over in this area.
Yes my boxers are very nosy and always in my business lol...
Back seat.
I have the third row seats. They appear to have been chewed on in a few spots by a rodent. Not bad, I can get pics.
Video of a quick drive. Sorry for it being shaky, old school digital camera. No Go Pro or smart phone...
Runs great, turbo spools up nicely. It will get up to about 15 lbs or so of boost on acceleration and up hills. I have had the boost get up around 18-19 lbs taking it up a big hill. Shifts very nicely as well. Hard to tell in the video.
The OD light sometimes flickers on/off, just something I noticed. The torque converter lockup is on the OD button but does not seem to affect the dash light.
Sounds like a typical 4BT does which is similar to the sound and noise of a Dodge first gen Cummins 6BT. Typical to my drive, boxer head hanging out each rear sliding window. Windows were rolled down in the video.
Thanks for looking.
