- Location
- United States
1993 1FZFE engine and transmission, 260K miles. Engine likely has a blown head gasket - haven't pulled the head to confirm, but that's the most likely issue - block test showed exhaust gas in the coolant. Before that, it ran great.
Engine has Photoman's alternator bracket and a 120A Sequoia alternator.
PS pump replaced about 2 years ago. I have some additional tune-up parts as well that I'll throw in - plugs, wires, distributer cap & rotor.
Wiring harness is pretty chopped up, but you can have what's left.
The transfer case is in the pictures but is NOT included.
$600 OBO
I'd prefer local pickup, but may consider shipping. I've never shipped something like this before, so some guidance & patience would be required.
Some additional parts available separately, or with the engine:
- MAF $30
- Early style (square outlet) air cleaner top $20
- Stainless steel intake tube & silicone adapters $40
- ECU $40
- Transmission controller $40
- Ignitor $30
- Fuel pump relay & resistor $20
- Fan & modified blue hub fan clutch $40
- Cruise control ECU & actuator (something in this system was not working - not sure which part) $20
$600 OBO
- MAF $30
- ECU $40
- Ignitor $30
