1989 FJ62 Fuel Pump fuse
West Covina, California
Hello,
Any of you know does FJ62 has fuel pump fuse? My truck does not seem sending fuel, it crank and engine never start. Truck has been sitting for a few months, but it was fine before, every couple months i warm up and its fine. Now engine would not start. Please kindly suggest.
Hello,
Got the exact same issue with mine currently. Getting a code 51 for the Throttle Position Sensor (TPS), so I have a new one on order. I've changed the spark plugs, installed new fuel filter, cleaned the throttle body, installed new battery, and it will run fine on starting fluid. Next move is to drain the fuel tank, and add fresh gas while I wait for the TPS to arrive.
Were you able to figure out your issue?
EFI Relay come to mind as something to check. Located on passenger inner fender next to air cleaner.
Connect +B and Fp terminals in diagnostic port to bypass ECU and relay. That will tell you if those are the culprits.
I smashed my O2 sensor wires and shorted them rock crawling. Then the truck wouldn’t run. So O2 sensors are important.
1955317
EFI Fuse is something to check. 15 amp at bot left of your fuse block. The FSM has an entire section dedicated to troubleshooting what you are doing with step by step checks.
1955318
Download and start reading the FSM:
1955320
1955321
1955322
