1988 LN85 Hilux Front End Refresh - Shopping list?
Adelaide, South Australia
Hi there,
I've never worked on an IFS front end before. I wish to completely rebuild the front end of my 4x2 1988 LN85 Hilux. The vehicle has around 280,000miles on it so I'm keen to replace just about everything that I can.
I'm after a shopping list of parts that should be sourced prior to starting work. Bearings, bushings, tie rod ends and other bits that I likely don't know the name of at this time.. and... go! :)
unpopular opinion: if it aint broke, don't fix it.
seriously though, if the parts aren't sloppy i wouldn't bother. especially if you aren't going to use oe parts. inspect, grease as necessary and enjoy that little truck.
There's a minor clunk when dry steering that shouldn't be there.. definitely keen to refresh the lot
I have done ball joints, sway bar links, tie rods, a- arms, etc. As Gnob says, don't do it unless there is an imminent failure diagnosed. I pulled my 30 year old ball joints, and they were still in usable shape. I keep them as spares. I have repacked my bearings on the front numerous times, but it's a 4wd. Not sure what's involved with the front bearings on a 2wd.
I've picked up all the parts below.. this follows a quote from a local mechanic ($US2900) for a rebuild of the steering/ball joints/and control arms bushes.. it was very much a "I really dont want this work" quote
IFS has been a mystery to me, but the more videos I watch and the more I look into it the clearer its all becoming.. I am feeling increasingly confident about the upcoming work that I'll start this weekend.
Total parts cost $US380 ($AUD605)..
The Idler Arm's connection to the Relay Rod was almost certainly approaching failure..
How do your CV boots look? I've repacked and rebooted my OEM ones several times over 20+ years.
4x2, thankfully no CVs to deal with - that upgraded Idler arm looks nice.. overkill for my application though thankfully (ouch on the price!)
New tie rod ends, new relay rod, new steering idler today! Did a basic alignment and it drives well..
Ball joints in a few weekends time.
did you put the a-arms at ride height for alignment ?
I did not.. that seems like a suboptimal mistake.. I will do again. First time doing this. I could jack the lower control arm up.. but if I put the tyres on I wont be able to get a straight edge on the rotors. When the ball joints are done I'll get it in for a proper adjustment I think.
you can just put it on jacks or blocks without wheels to get the suspension loaded
Ah.. interesting, thank you!
Upper and lower ball joints done today, and new rotors..
