Electric mirror control needed
I am interested in the driver rear door mine is smashed in and is the same color how much shipped to 27965
Thanks
Tommy
Clean front and rear bumpers available with caps? Rear hub center caps, Chrome trim on drip rail above tailgate?
Thanks
how much for the power lock mechanism inside the tailgate? shipped to VA 22963, also interested in the drivers side front rain gutter trim piece if no damaged.
I'll check on these and get some pics.Crossing my fingers on this stuff.
I am in need of some sensors off of your thermostat housing. Honestly it would probably easier to just get both of the upper and lower housings from you to avoid breaking the sensors upon removal. Need the cold start timer switch (182-66) and water temperature sensor (182-65) from the picture on Specter.
I also need the connector and a bit of wire to repair my broken harness at the Water Temperature Switch, if you are willing to cut your harness. P/N 182-67 on the picture on Specter.
I would also like the fusible link mounted near your battery. It has three wires coming from the positive terminal headed into the arenas with two rather large quick disconnect connectors on each end.
